Remote start not powering a/c
camarob4c1
Member - Posts: 28
Posted: October 09, 2004 at 11:39 AM / IP Logged
I installed the crime guard 745i2 and the omega rs-4lx in the 95 mustang convertible.
It starts the car, but is not providing power to the a/c unit.  I hooked the Blue wire to the Ignition #1and the yellow to the little yellow on the 745, the white is going to the parking lights.
Do I need to hook the blue to a second or more Ignition wires?
Thanks again, tas
zargon
Copper - Posts: 186
Posted: October 09, 2004 at 2:23 PM / IP Logged
there will be another wire which fires up the ac gray and yellow are common acc colors with ford.
camarob4c1
Member - Posts: 28
Posted: October 09, 2004 at 6:45 PM / IP Logged
Well I honestly do not understand.  I think since I moved the 4lx yellow wire from the car's IGN#2 to the 745's small yellow wire (to keep the alarm from going off during remote start), that I maybe need to move the 4lx white wire from parking lights to the IGN#2.
But if I do that, what will I use to power the parking lights during remote start?
I am missing something here!  Or do I just hook the 4lx blue wire that is connected to IGN#1 to IGN#2 also?
tas
mo12v
Posted: October 09, 2004 at 9:00 PM / IP Logged
Check P M
Don't let it confuse U
MO
camarob4c1
Member - Posts: 28
Posted: October 10, 2004 at 11:54 AM / IP Logged
I have the:
black to ground
red to the positive battery
blue to IGN#1tan/white
green to starter
yellow is now connected to the small 745i2 yellow (it was hooked to IGN#2, but we moved it to keep the alarm from going off during remote start)
white to parking lights
gray not used
violet to brake pedal
green to hood pin
orange to tach lead
pink to the aux#3 on the 745i2
white 18ga not used
pair of blue 18ga are spliced into the grounds of the shock sensor and the dual zone sensor
If I read the instructions correctly the yellow or white must be used for IGN#2 to operate accessories, such as a/c, etc.  Or you may have to connect to even a third IGN.
Thanks again for your help,
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
