Alarm + Remote Start in 99 Toyota 4Runner
Robacarp
Posted: October 11, 2004 at 8:06 PM / IP Logged
Hello,
I am going to be installing an alarm and remote start in a friends 1999 Toyota 4Runner, and I cant for the life of me seem to find any websites that can give me the install info that I need for the car.   If this is unclear what I mean, I mean that I cant find the wire locations for the locks, lights, ect.  I could find them on my own, but sometimes that can be really frustrating and annoying.
So, does anyone know of a website where I can get that info (or even better, does anyone have that info they could email me?)\
Thanks.
also, if this post is going into the wrong forum, sorry about that.
Robert Carpenter
Teken
Gold - Posts: 1,492
Posted: October 11, 2004 at 9:17 PM / IP Logged
Toyota
4-Runner
1999-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   GREEN/ BLACK
IGNITION SWITCH HARNESS *
Ignition #1:
   BLACK/ RED
Ignition #2:
   BLACK / YELLOW
Ignition #3:
   N/A
Accessory:
   BLUE/RED
Brake Light:
   GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   BLACK
AT IGNITER ON PASS. WHEELWELL **
Parking Lights:
   RED / GREEN (-)
AT ALARM MODULE
Headlights:
   RED (-)
AT HEADLIGHT SWITCH ***
OEM Alarm Disarm:
   YELLOW/RED (-)
Key Sense Wire Found Below Steering Column****
OEM Alarm Arm:
   BLACK / YELLOW (+)
AT ALARM MODULE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * 2000 Vehicles May Be Equipped With a Transponder Type ** BLACK Tach Wire Also Found In Data Link Connector On Driver Side Of Engine (4 Cyld.) Or At Engine Control Module Located Behind Pass. Dash (6 Cyld.) Or Can Also Be Found In 26 Pin Connector In Pass. Kick Panel On Both.
Toyota
4-Runner
1999-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE/ RED & WHITE
Starter Kill:
   GREEN/ BLACK
Ignition +12 Volts:
   BLACK/ RED
Dome Lights/Superv:
   GREEN/ BLACK (-)
AT DOME LIGHT
OEM Horn:
   GREEN/ RED (-)
AT ALARM MODULE
Power Lock:
   RED / WHITE (-)
WHITE CONN. ABOVE BLUE IN DR. KICK***
Power Unlock:
   RED (-)
Trunk Release:
Alarm Input Wire:
   GREEN/ BLACK (-)
AT DOME LIGHT
Notes:
** Fuse Block Located In Driver Dash. *** Child Safety Locks: RED / BLUE (-) In Same Conn. As Door Lock Wires Above. See Note #209 - See Child Safety Locks Diagram. Lock Wires Are Also Found At Alarm Module. Lock BROWN / White (-) Unlock GREEN/ YELLOW (-. **** Use Ignition 3; Negative Out While Running.
Teken
Gold - Posts: 1,492
Posted: October 11, 2004 at 9:19 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / 4RUNNER / 1999 / Remote Start
12volts white - WHITE/ red    +   ignition harness
Starter GREEN/ black or black    +   ignition harness
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Second Ignition blk/red    +   ignition harness
Third Ignition
Accessory blue/red    +   ignition harness
Second Accessory
Keysense
Power Lock BROWN / white    -   plug below fuse box
Notes: The door lock wires will meter while turning the key in the passenger door key cylinder.
Power Unlock grn/yel & blu/yel    -   plug below fuse box
The GREEN/ YELLOW wire is the key cylinder unlock wire, the blue / YELLOW wire is the unlock detection wire. Use both wires and diode isolate.
Lock Motor blue/white      driver kick blue 12 pin plug
Unlock Motor pink/green      driver kick blue 12 pin plug
Parking Lights+ green      dimmer or harness to rear
Parking Lights- RED / white      light switch or column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. GREEN/ black    -
Notes: behind drivers side junction block in a 13 pin plug.
Dome Supervision use door trigger    -
Trunk/Hatch Pin tied in with door    -
Hood Pin GREEN/ orange    -
Notes: drivers side firewall in a gray 26 pin plug.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock yellow/red    -   steering column
Notes: This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.
Tachometer black
Notes: located in the diagnostic plug on the drivers side of engine compartment.
Wait to start
Brake Wire GREEN / WHITE    +   at switch
Parking Brake
Horn Trigger GREEN/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 555X, 556U, or 555U
Notes: N/A
Teken
Gold - Posts: 1,492
Posted: October 11, 2004 at 9:21 PM / IP Logged
Toyota 4Runner 1999
Remote start / Security / GPS
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS White or WHITE/ red Ignition harness +
IGNITION BLACK / YELLOW Ignition harness +
IGNITION 2 BLACK/ red Ignition harness +
ACCESSORY Runs with ignition Ignition harness +
STARTER GREEN/ black Ignition harness +
TACH See notes*
LOCK BROWN / white In driver's kickpanel -
UNLOCK Blue/black & RED / blue** In driver's kickpanel -
DOORPIN SEE NOTES***
TRUNK PIN Lt.GREEN/ red In driver's kickpanel -
TRUNK RELEASE Manual release
FACTORY ARM Arms with lock wire
FACTORY DISARM Disarms with unlock wires
BRAKESWITCH GREEN / WHITE At switch above brake pedal +
PARKLIGHTS Green At light switch harness +
HAND BRAKE RED / white At plug on handbrake lever -
HORN GREEN/ red At steering column -
CLUTCH SWITCH BLACK/ white At switch on clutch pedal TYPE 1
DRIVER WINDOW UP Lt.green At main window switch REV POL
DRIVER WINDOW DOWN Blue / YELLOW At main window switch REV POL
PASSENGER WINDOW UP RED / black At main window switch REV POL
PASSENGER WINDOW DOWN RED / green At main window switch REV POL
LEFT REAR WINDOW UP RED / blue At main window switch REV POL
LEFT REAR WINDOW DOWN RED / yellow At main window switch REV POL
RIGHT REAR WINDOW UP Yellow At main window switch REV POL
RIGHT REAR WINDOW DOWN Green At main window switch REV POL
HEADLIGHTS RED / yellow At light switch harness -
REVERSE LIGHTS RED / white In driver's kickpanel +
DIMMER WHITE/ green At dimmer switch harness
VSS WIRE GREEN/ orange**** At ECM behind glove box****
KEY SENSE Yellow/red Ignition harness -
Vehicle notes
PLEASE NOTE: This vehicle may be equipped with a IMMOBILIZER passive anti-theft system. Please refer to our security diagram before installing any remote start products.
* On the 2.7L engine there are 2 coils on the right front of the engine. Use the BLACK/ RED or BLACK/ BLUE for a 2 cylinder signal. On the 3.4L, the tach is BLACK at the igniter on the right side of the engine (6 cylinder signal).
You can also find a tach reference at the ECM module behind the glovebox. On the 2.7L, BLACK at pin-15 of the 26-pin connector.
** Both these wires must be connected and isolated with 2 IN4001 diodes. This will require 2 pulses to unlock the doors.
*** Doorpins are independent. Driver's door is BLACK in driver's kickpanel, rear doors are BLACK/ RED in driver's kick and BLACK/ WHITE is passenger door on back of fuse panel.
**** The GREEN/ ORANGE vss wire is located at the ECM behind the glovebox. On the 2.7L, pin-8 of the 22-pin connector. On the 3.4L, pin-22 of the 28-pin connector.
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
©2002 Autoland All rights reserved
Printed at: 10/11/2004 10:18:57 PM
Teken
Gold - Posts: 1,492
Posted: October 11, 2004 at 9:22 PM / IP Logged
TOYOTA 4-RUNNER 1999
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHT OR WHT/RED
IGNITON SWITCH HARNESS
IGNITION 1 BLK/YEL IGNITION SWITCH HARNESS
IGNITION 2 BLK/RED
IGNITION 3 N/A N/A
ACCESSORY /HEATER BLOWER 1 BLU/RED IGNITON SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2        N/A
STARTER GRN/BLK OR GRN IGNITION SWITCH HARNESS
PARKING LIGHTS GRN (+) AT LIGHT SWITCH
DOMELIGHT BLK(dr) BLK/RED (rear) DR KICK PANEL
PWR DOOR LOCK BRN/WHT (-) DR KICK PANEL
PWR DOOR UNLOCK RED (-) & RED / WHT TYPE B *SEE DIAGRAM*
TRUNK RELEASE N/A N/A
TACH SENSOR BLK AT DIAG CONNNOR IGNITOR (PASS FENDER)
BRAKE
GRN/WHT (+) SWITCH ABOVE BRAKE PEDAL
HORN
N/A N/A
FACTORY DISARM
W/LOCKS N/A
N/A N/A
Robacarp
Posted: October 14, 2004 at 7:38 PM / IP Logged
holy cow.
thanks for the replies!  I should be able to get it done between the three of them.
Can I ask where you people get this info?
Robert Carpenter
mo12v
Posted: October 14, 2004 at 7:44 PM / IP Logged
This one to:
Constant 12 voltsWHITE/ RED & WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterGREEN/ BLACKIGNITION SWITCH HARNESS
Dome LightL GREEN/ RED (-)11 PIN CONN. IN DRIVER KICK PANEL *
Trunk Pin SwitchBLUE/WHITE (-)AT SWITCH IN REAR DOOR.
Parking LampGREEN (+)AT FUSE BOX IN DRIVER KICK PANEL
Power LockRED / WHITE18 PIN CONN. IN DRIVER
Power UnlockREDKICK PANEL **
* Optional Door Trigger At Body ECU Located Behind Driver Dash In Fuse Block BLACK (Dr) (-), BLACK/ WHITE (Ps) (-) & BLACK/ RED (Rear Doors) (-). Diode Isolation Needed Cathode (Band Side) Of Diode Faces OEM Wires. ** Child Safety Locks: RED / BLUE (-) In 12 Pin BLUE Connector In Driver Kick
Accessories
Window UpD\ L GREEN P\ RED / BLK D\ RED / BLU P\ YELLOW @ MAIN SWITCH
Window DownF/ BLU/YEL F/ RED / GRN R/ RED / YEL R/ GREEN
Ign Key Warn
Trunk ReleaseN/A
OEM HornGREEN/ RED (-)STEERING COLUMN HARNESS
HeadlightsRED (-)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmBLUE/BLACK (-)18 PIN CONN. IN DRIVER KICK
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLACKAT ECM BEHIND PASSENGER SIDE DASH
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS #239
Ignition #3N/AIMMOBILIZER TRANSPONDER CIRCUIT
AccessoryBLUE/REDIGNITION SWITCH AHRNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PADEL
Reverse LightRED / YELLOW (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
 Immobilizer Bypass Circuit
MO
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 9:58 PM / IP Logged
ASAP requests are all copy and pasted from various internet security sites.
Actual PDF form schematics are sent via e-mail upon the users request(s), if they wish to view them in their original form.
As always the information provided is simply a guide. It is not intended to replace the varification of the contact points without the use of a DMM, and one good working brain.
P.S.
You will find that mo12v will always supply you with a better *looking* wiring form. Just because he has to make me look bad !! [:o]
Regards
EVIL Teken . . .
mo12v
Posted: October 14, 2004 at 10:01 PM / IP Logged
That's NOT true.............I like your B & W presentation better.......It's easier on the eye's      Alarm + Remote Start in 99 Toyota 4Runner -- posted image.
MO
Robacarp
Posted: October 15, 2004 at 9:56 AM / IP Logged
Yea, the only thing that I makes me think about the internet security sites is that I couldnt find any that would give the information for free....they all wanted me to pay ......
Thanks everyone
Robert Carpenter
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
