Directech info needed. '95 Dodge Ram
Welcome Guest :)
onstottc
Member -
Posted: October 14, 2004 at 4:39 PM / IP Logged
Could someone with access to directech please send me the wiring info for a 1995 Dodge Ram? I'm installing a python 881xp in mine.
Thanks in advance!
Teken
Gold -
Posted: October 14, 2004 at 5:01 PM / IP Logged
1995 Dodge Ram Pickup
Item Wire Color Polarity Wire Location
12V red or pink/black + ignition harness
STARTER yellow or blu/yel + ignition harness
IGNITION dk. blue + ignition harness
ACCESSORY BLACK/ orange + ignition harness
SECOND ACCESSORY none
TACHOMETER gry/blk, blk/gry ignition coil *1
POWER LOCK ORANGE / purple 5wi lt blue plug in driver kick
POWER UNLOCK pink/purple 5wi lt blue plug in driver kick
PARKING LIGHTS + BLACK / YELLOW yellow plug in driver kick
PARKING LIGHTS - none
DOOR TRIGGER yellow - yellow plug in driver kick
HEADLIGHTS lt. green + steering column
WIPERS RED / yellow + wiper switch
LF WINDOW UP/DN lt. blue - white A drivers door switch
RF WINDOW UP/DN brn/wht - pur/wht A drivers door switch
LR WINDOW UP/DN none
RR WINDOW UP/DN none
TRUNK/HATCH PIN none
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM none
FACTORY ALARM DISARM none
HORN TRIGGER dk. GREEN/ red *2 + relay at fuse box
BRAKE WIRE WHITE/ brown + brake pedal switch
LOCK MOTOR none
UNLOCK MOTOR none
DISARM DEFEAT none
DISARM NO UNLOCK none
DOME SUPERVISION use door trigger
SPEED SENSE none
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER none non none
RF SPEAKER none non none
LR SPEAKER none non none
RR SPEAKER none non none
RADIO 12V none non none
RADIO GROUND none non none
RADIO SWITCH none non none
RADIO ILLUMINATE none non none
POWER ANTENNA none non none
Notes: *1 Also located as gray/blue at large plug through firewall on driver's side at highest point of firewall, also gray/blue at cluster. Diesel wait to start wire is ORANGE / black (-) at the PCM (Powertrain Control Module) on the passenger side firewall under the hood. *2 Also BLACK/ red (-) at column or relay.
onstottc
Member -
Posted: October 14, 2004 at 5:08 PM / IP Logged
Thanks! Now the fun begins.
Sunday, May 19, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
