2002 Ford Focus Alarm/Keyless Entry Wiring
Welcome Guest :)
bwharvey
Member -
Posted: October 16, 2004 at 11:03 PM / IP Logged
I have to add on keyless entry to an exsisting aftermarket alarm installed by someone else. I need to know lock system type (negative, resistors etc.) I haven't done one of these vehicles before. If any one has a guide or can give me a tip to save some time would be appreciated. My e-mail is bkharvey@telus.net
Thanks Bwharvey
boomer_106
Silver -
Posted: October 17, 2004 at 9:44 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | GRAY/BLACK | IGNITION SWITCH HARNESS |
Ignition #1: | | GREEN/ YELLOW | IGNITION SWTICH HARNESS* |
Ignition #2: | | N/A | |
Ignition #3: | | N/A | |
Accessory: | | YELLOW | IGNITION SWITCH HARNESS |
Brake Light: | | GREEN/ RED (+) | AT SWITCH ABOVE PEDAL ** |
Tach Signal: | | BLACK/ LT. GREEN | AT COIL MODULE |
Parking Lights: | | ORANGE / YELLOW (+) | AT LIGHT SWITCH |
Headlights: | | | |
OEM Alarm Disarm: | | BLUE/LIGHT GREEN | IN DRIVERS KICK PANEL |
OEM Alarm Arm: | | | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * This Vehicle Is Equipped With Ford's Passive Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** This Wire Is Only Active When The Ignition Is On. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED | IGNITION SWITCH HARNESS |
Starter Kill: | | GRAY/BLACK | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | GREEN/ YELLOW | IGNITION SWTICH HARNESS* |
Dome Lights/Superv: | | | |
OEM Horn: | | | |
Power Lock: | | BLACK/ RED (-) | DRIVER'S KICK IN DOOR BOOT *** |
Power Unlock: | | BLACK / YELLOW (-) | DRIVER'S KICK IN DOOR BOOT *** |
Trunk Release: | | BLACK / YELLOW (-) | AT TRUNK RELEASE SWITCH |
Alarm Input Wire: | | | |
Notes: | | *** See Installation Note # 201 - Negative Pulse Door Lock Diagram |
bwharvey
Member -
Posted: October 17, 2004 at 10:15 AM / IP Logged
Thanks boomer_106 I'm going to do this add on this morning so it was perfect timing for the info. Thanks again
boomer_106
Silver -
Posted: October 17, 2004 at 10:25 AM / IP Logged
Your Welcome. Glad I could help. Good luck
Thursday, May 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
