remote start on a 2002 saturn vue
Sexified
Copper - Posts: 87
Posted: October 18, 2004 at 8:30 PM / IP Logged
anyone have the wiring information for the saturn vue?
is it anything like the sedans with the disarm wire under the rear seats?
i want to do locks and the usual remote start intergration.
thanks in advance
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 8:41 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SATURN / VUE / 2002 / Remote Start
12volts orange   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Notes: The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on.
This wire is also found in pin A11, gray 24 pin plug at BCM.
Power Lock RED / black   +   pin A8, gray 16 pin plug at BCM
Notes: The BCM (Body Control Module) is in the center of the dash behind the pocket.
Power Unlock ORANGE / black   +   pin A7, gray 16 pin plug at BCM
To unlock just the driver door use a lt. green (+) wire in pin A2, gray 16 pin plug at BCM.
Lock Motor gray   5wi driver kick, door harness
Unlock Motor tan   5wi driver kick, door harness
Parking Lights+ brown   +   pin B10, gray 24 pin plug at BCM
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt. blue   +   steering column
Turn Signal(R) dk. blue   +   steering column
Reverse Light lt. green   +   kick panel, harness to rear
Door Trigger gray/black (D), BLACK/ white(P) -   gray 24 pin plug at BCM
Notes: The driver door trigger is gray/black in pin B2. The passenger door trigger is BLACK/ white in pin A12. Use both wires and diode isolate each.
Dome Supervision use door trigger wire
Trunk/Hatch Pin RED / black   -   pin B4, gray 24 pin plug at BCM
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote or passive
Notes: The factory alarm is programmable for Active, Passive (5 minute delay), or Disabled. Turn ignition on, press PANIC button 8 to 10 times in 5 seconds. Within 3 seconds press UNLOCK button for Disabled, LOCK button for Active, or LOCK button twice for Passive.
Factory Alarm Disarm factory remote only
Disarm No Unlock disarms with remote start
Tachometer NOT pink or BLACK/ white   ac   ignition coil pack
Wait to start N/A
Brake Wire lt. blue   +   brake pedal switch
Parking Brake lt. blue   -   pin A2, gray 24 pin plug at BCM
Horn Trigger black   -   pin B2, pink 24 pin plug at BCM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: N/A
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 8:49 PM / IP Logged
Saturn
Vue
2002-2004
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   Yellow
Ignition Switch Harness
Ignition #1:
   Pink
Ignition Switch Harness*
Ignition #2:
   N/A
Ignition #3:
   N/A
Accessory:
   Brown & Orange
Ignition Switch Harness**special note
Brake Light:
   Blue or White
At Brake Switch
Tach Signal:
   White or Purple
At Coil Pack
Parking Lights:
   Brown (+)
At Headlight Switch
Headlights:
   No Color Available
Please call with information
OEM Alarm Disarm:
   No Color Available
OEM Alarm Arm:
   No Color Available
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
   No Color Available
Notes:
   *May be equipped with Passlock II or PassKey III transponder anti-theft system - Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The ACC wire from the module must drive two external relays to power up the Brown & Orange wire from the vehicle. The Brown & Orange wire MUST turn ON and OFF at the exact same time or this will cause a Check Engine Light.*** Connect this wire to a lt.green(-) keysense wire to prevent CEL light to come ON, All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the bypass module, if needed.
Saturn
Vue
2002-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   Orange (+)
Starter Kill:
   Yellow
Ignition +12 Volts:
   Pink
Dome Lights/Superv:
   Gry/Blk and Blk/white
At Door Pins****
OEM Horn:
   Black (-)
In steering Column Harness*****
Power Lock:
   RED / Black (+)
Driver Kick Panel******
Power Unlock:
   ORANGE / Black (+)
Drivers Kick Panel******
Trunk Release:
   No Color Available
Alarm Input Wire:
At Door Pins****
Notes:
****Individual door circuits - Must diode isolate door pins or go directly to dome light. The color at the dome light may vary. *****CAUTION - HARNESS MAY CONTAIN AIR-BAG WIRES. TO PREVENT INJURY OR VEHICLE DAMAGE, TEST ONLY WITH A DIGITAL MULT-METER SET FOR DC VOLTS! The correct horn wire will measure 12 volts when you are not pressing the horn, zero volts with the horn sounding. ******In drivers kick panel where the rubber boot comes from the door into the body of the vehicle. See Note #202 Positive Trigger Door Locks
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 8:50 PM / IP Logged
VUE 2002-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT ORANGE
IGNITION SWITCH HARNESS
IGNITION 1 PINK IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER ORANGE IGNITION SWITCH HARNESS
STARTER YELLOW IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) BROWN GRAY 24 PIN PLUG @ BCM PIN B10 *SEE NOTES BELOW* 1
DOMELIGHT GRAY/BLACK (L) AND BLACK/ WHITE (R) GRAY 24 PIN PLUG @ BCM *SEE NOTES BELOW* 2
POWER DOOR LOCK RED / BLACK ( + ) GRAY 16 PIN PLUG @ BCM PIN A8 *SEE NOTES BELOW* 1
POWER DOOR UNLOCK ORANGE / BLACK ( + ) GRAY 16 PIN PLUG @ BCM PIN A7 *SEE NOTES BELOW* 3 (TYPE A)
TRUNK RELEASE N/A
TACH SENSOR NOT PINK OR BLACK/ WHITE (AC) AT IGNITION COIL PACK
BRAKE
LT. BLUE ( + ) SWITCH ABOVE BRAKE PEDAL
HORN
BLACK ( - ) PINK 24 PIN PLUG @ BCM
FACTORY DISARM
DISARMS WITH REMOTE ONLY *SEE NOTES BELOW* 4
FACTORY ANTI-THEFT
PASSLOCK 2 791 REQUIRED
NOTES:
*1 - The BCM (Body Control Module) is in the center of the dash behind the pocket.
*2 - The driver door trigger is gray/black in pin B2. The passenger door trigger is BLACK/ white in pin A12. Use both wires and diode isolate each.
*3 - To unlock just the driver door use a lt. green (+) wire in pin A2, gray 16 pin plug @ BCM.
*4 - The factory alarm is programmable for Active, Passive (5 minute delay), or Disabled. Turn ignition on, press PANIC button 8 to 10 times in 5 seconds. Within 3 seconds press UNLOCK button for Disabled, LOCK button for Active, or LOCK button twice for Passive.
