how do i bypass the clutch?
duece02
Member - Posts: 7
Posted: October 02, 2002 at 10:49 AM / IP Logged
I have a 88 mustang. I installing a prestige 995. CAn any one help whit the clutch bypass?
Chris Luongo
Platinum - Posts: 3,746
Posted: October 02, 2002 at 10:13 PM / IP Logged
There should be a switch attached to the clutch pedal, with two wires coming from it.  Connecting the two wires together will allow the car to start at all times.  Or, use a relay to connect the two wires together only while the remote start is on; this will leave the factory clutch switch functional the rest of the time.
If there are two switches at the clutch, one of them is for the cruise control....trial and error will tell you which one you need to rewire.
chasesaccessori
Copper - Posts: 198
Posted: October 03, 2002 at 1:01 PM / IP Logged
I hope this is your own car and not someone elses.  If so you are opening yourself up to a lawsuit.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
garcia1980
Member - Posts: 14
Posted: October 03, 2002 at 11:02 PM / IP Logged
hello,
Will this work w/ any clutch system (celica 95)!!!!!
mobiletoys2002
Gold - Posts: 1,050
Posted: October 04, 2002 at 5:43 AM / IP Logged
if the car runs someone over no matter whos car it is he has a lawsuit coming.. BE CAREFULL you need to make some sort of safety switch with the emergency brake or dont do it at all.this is more dangerous then many people think.
garcia1980
Member - Posts: 14
Posted: October 04, 2002 at 9:14 AM / IP Logged
hello all,
hey, mobiletoys2002... whats the best way to make a safety switch on the emergency brake for this weird application?
thanks
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
