How To Wire 2 JL 12W7’s?
riverboyskennel
Posted: October 25, 2004 at 10:10 AM / IP Logged
i have 2 jl audio 12w7 3ohm subs and i have a us amps de1000 what is the best way to wire the subs up?  does any 1 have a diagram?...thanks
riverboyskennel
94legend
Silver - Posts: 237
Posted: October 25, 2004 at 12:42 PM / IP Logged
On your US Amp, i dont' know much about them, but what are its specs? 2 channel , mono, etc.
94legend
Silver - Posts: 237
Posted: October 25, 2004 at 12:46 PM / IP Logged
Well here would be a good way to run them. I use this diagram alot.
Option one or two would be just good. Depending on your amp!
How To Wire 2 JL 12W7’s? -- posted image.
If you have any questions let me know.
riverboyskennel
Posted: October 25, 2004 at 5:18 PM / IP Logged
hi, it's ratings are as listed...
How To Wire 2 JL 12W7’s? -- posted image.Mono Channel Class "DE" Amplifier
How To Wire 2 JL 12W7’s? -- posted image.Total Power Output: 1000 Watts RMS
How To Wire 2 JL 12W7’s? -- posted image.THD at Rated Power: <0.1%
How To Wire 2 JL 12W7’s? -- posted image.Signal/Noise Ratio: >86dBA
How To Wire 2 JL 12W7’s? -- posted image.Damping Factor: >200
How To Wire 2 JL 12W7’s? -- posted image.Fuse Rating: 100 Amps
How To Wire 2 JL 12W7’s? -- posted image.Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
298mm / 11.75in Long
How To Wire 2 JL 12W7’s? -- posted image.Weight: 3.85kg / 8.50lb
How To Wire 2 JL 12W7’s? -- posted image.Variable 24dB Low-Pass Active Crossover
How To Wire 2 JL 12W7’s? -- posted image. How To Wire 2 JL 12W7’s? -- posted image.
How To Wire 2 JL 12W7’s? -- posted image.2 Ohm Recommended Load
How To Wire 2 JL 12W7’s? -- posted image.1˝ Ohm Minimum Load
How To Wire 2 JL 12W7’s? -- posted image.1000 Watts x 1 into 2 Ohms
riverboyskennel
94legend
Silver - Posts: 237
Posted: October 25, 2004 at 8:47 PM / IP Logged
Not bad at all. I like that clear glass visual look on that amp.! just let me know how its going with your setup.! good luCk!
You lucky son of a B$%&^ i just remembered you have 2 JL 12w7's !  to expensive!!
Db160
Member - Posts: 9
Posted: October 26, 2004 at 6:29 PM / IP Logged
those things are gonna be way underpowered.you could probably put 1000 watts on each one of those things.Are you going ported or sealed with your enclosure?Are they 3 ohms per coil?or are they 3 ohms per sub?if they are 3 ohms per sub you could either wire them parallel for a 1.5 ohm load or wire in series for a 6 ohm load.If your amp will be stable at that 1.5 ohm load thats what i'd shoot for because at 6 ohms your not gonna get much power.if they are dual 3 ohm voice coil subs you could do some series-parallel wiring and get a 3 ohm load to the amp or do some series wiring and get a 12 ohm load which would suck.the choice is yours.Wire them as low as your amp will handle for the most power.
John Bennett
2000 Michigan Points Champ
2000 World finalist (dB Drag)
Retired until I hit the lotto
uthinkuknoaudio
Silver - Posts: 760
Posted: October 27, 2004 at 7:05 PM / IP Logged
db160 is clearly not that informed if he says that 1000 W from a US AMP isn't enough to power two of those bad boys. What u can do is run those suckers up parallel so you can achieve a 1.5 ohm load which is stable by that amp. W7's are single 3 ohm, so that is what you should do to utilize your power. Remember, it is 1000 W RMS into a 2 ohm load, so your pushing about 1500 WRMS at 1.5 ohms, so henceforth 750 WRMS x 2 to those speakers, and boy they will crank. I have heard them at 1000 W input before and it is nothing u can't achieve with 750 W of especially US AMP power. FYI  -  US Amps make the best out there in the amplifier companies. Built right here in Florida by hand, these bad boys are the most efficient things you will ever see. You will definitely not be dissappointed. Enjoy your fine audio products.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Db160
Member - Posts: 9
Posted: October 28, 2004 at 7:37 PM / IP Logged
why would you spend so much on a pair of subs and then not even push them to their full potential? I never said it wouldn't slam with that much power but just think about how much cleaner and louder it could be if you had enough extra power on tap to utilize the full capabilities of the subwoofer.Thats like buying a viper and never putting the pedal all the way to the floor.
John Bennett
94legend
Silver - Posts: 237
Posted: October 29, 2004 at 9:44 AM / IP Logged
Most likely because he does not wish to put out any more money, and just use what he has.  I would have to agree, selll the current amp, and get maybe a 500/1 jl amp. But hez probably already spending $1000 or so just for the subs. Not sure what the deal is, but seems like he has a financial problem. Well good luck with your w7's
riverboyskennel
Posted: October 29, 2004 at 9:59 AM / IP Logged
 i want to thank you people for helping with my question....why should  i sell my amp??? the de1000 i have puts out 1800 watts at 1.5 ....i think thats plent for right now...and as far as the subs go why not spend the money? you pay for what you get ....id like to see any other sub , kicker ,mtx etc...do what these jls do and still keep going..... thanks.....
riverboyskennel
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
