autopage alarm - need help
dalmyd1
Member - Posts: 27
Posted: November 10, 2004 at 11:18 AM / IP Logged
I installed an autopage 850 in an 04 GMC YUKON.  Here lies the problem.  The alarm says that the car started although it hasn't (it won't even crank over).  The minute I put my power probe in the starter line on the alarm brain it cranks over.  It has a lowjack system in it.  Does that have anything to do with it?  When it does want to crank over it starts just fine eliminating the by-pass module as the problem.
Thanks for all your help guys.......
Moderator - Posts: 12,488
Posted: November 10, 2004 at 11:20 AM / IP Logged
Did you install a starter disable relay ? Do you have the right wire to the starter motor and the right wire to the switch ?
dalmyd1
Member - Posts: 27
Posted: November 10, 2004 at 9:53 PM / IP Logged
Yes it does have a starter kill, however, i've tried disconnecting it, and putting the starter wire from the alarm directly on the starter wire and it still does the same thing.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
