Which Slot Design?
Gbelous
Member - Posts: 30
Posted: November 11, 2004 at 12:06 PM / IP Logged
Which of these designs would sound the best.  Keep in mind these images are just quick sketches and the dimensions aren't accurate.  Where whould the slot vent come out?
Which Slot Design? - Last Post -- posted image.
Francious70
Silver - Posts: 629
Posted: November 11, 2004 at 12:44 PM / IP Logged
This is the only way I've seen it done.
But I suspect that numbers 1 & 4 should sound fine as long as you have them tuned properly and what not.
Paul
stevdart
Platinum - Posts: 5,816
Posted: November 11, 2004 at 11:24 PM / IP Logged
I don't think any of them would sound best...or worst.  It depends on how long the port length has to be for your sub(s), and how much linear space you have to put it in.  Don't make the slot opening too small just so that you can put in a shorter port length.  Keep the port opening large enough that you don't get chuffing when air is expelled, and with a larger opening comes a longer port length.  Fold the port in the box as necessary to achieve the length needed.  The port opening can be on any side of the box, but in cases where the driver is directed directly into the car interior the port should be also.
Gbelous
Member - Posts: 30
Posted: November 12, 2004 at 8:13 AM / IP Logged
Thanks.  I have come up with a new scheme and will post it on my car domain site.  If anyone notices any issues with it let me know.  Thanks for all the help!
ravenndude
Silver - Posts: 250
Posted: November 12, 2004 at 11:03 AM / IP Logged
Disregard this post ... i made a mistake
jeffchilcott
Platinum - Posts: 2,483
Posted: November 12, 2004 at 3:54 PM / IP Logged
I would go with 4 and only 4    its the only one where the port and sub and firing aginst each other
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
