Odyssey Sliding doors
mbsaudio
Copper - Posts: 80
Posted: November 13, 2004 at 4:22 PM / IP Logged
Anyone with some wiring info the the sliding doors for the 1999 Honda Odyssey. There is a diagram available but it shows for both doors together. I would like one for each door individually on seperate outputs. Wire colors would help also.
Moderator - Posts: 12,488
Posted: November 13, 2004 at 5:16 PM / IP Logged
Honda_Odyssey_slide_doors.pdf
Here you go. Here you will need 4 (-) triggers to operate the open and cloing of each door.
mbsaudio
Copper - Posts: 80
Posted: November 13, 2004 at 7:05 PM / IP Logged
This is somewhat of what I'm looking for Jeff, but the diagram on your CD shows using the same trigger to open and close the doors using the door pins. The door pins change from positive to negative depending on if the door is open or closed. By using a couple of relays the same trigger can close and open the door. Refer to directfax document #1085. Thanks.
auex
Platinum - Posts: 5,041
Posted: November 14, 2004 at 12:23 AM / IP Logged
Well, here is 1085.
Jeff's way seems much easier and less parts involved.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mbsaudio
Copper - Posts: 80
Posted: November 14, 2004 at 5:59 AM / IP Logged
Beautiful, thats what I'm looking for. Thanks bundles.
Is this the diagram on the CD? My CD is from 2003, but I've got a new one or order. Cost @ $100 CND. Wire magic: $350 CND. I just laughed at them. Thanks alot guys.
auex
Posted: November 14, 2004 at 10:22 AM / IP Logged
What CD???
On second though I don't care.
mbsaudio
Copper - Posts: 80
Posted: November 14, 2004 at 5:04 PM / IP Logged
The one from VelocityTech, by Velocity Motorsports. Where did you get your diagram from?
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
