Auto Antenna Help?
mrdragon
Copper - Posts: 121
Posted: November 16, 2004 at 6:04 AM / IP Logged
Guys i got a Mazda 626 1992 which had Automatic Antenna, and i just purchased Cd Player for my car and there is not remote wire. So is there any ways i can hook it up with my Mazda so that the Automatic Antenna will work???
Thanks !
supradude
Silver - Posts: 915
Posted: November 16, 2004 at 7:36 AM / IP Logged
What kind of cd player did you buy? I haven't seen one that doesn't have a remote wire. But if it doesn't, you can hook up the antenna still. You will have to use a toggle switch and turn it on and off when you want to hear the radio.
'85 Toy
furflier
Copper - Posts: 236
Posted: November 16, 2004 at 7:37 AM / IP Logged
What brand & model is your cd player? If you don't have a power antenna wire or remote turn on, you can run a wire to your fuse block & connect it to acc fuse.
kgerry
Platinum - Posts: 3,455
Posted: November 16, 2004 at 8:34 AM / IP Logged
if my memory serves me correctly a lot of the older Mazda's used a ground to activate the antenna, not 12V... and you have to use a relay to convert it..... when metering your wiring you may want to keep this in mind....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
