Keyless entry, problem
spaceace
Member - Posts: 8
Posted: November 20, 2004 at 6:31 PM / IP Logged
I bought a keyless entry and security system called Huge-SunI M-1000, and I am trying to install it to a 1999 Opel/Vauxhall Corsa B and I got a lot of problems with installing it, the security system works fine but I don't know what wires I have to connect to the central lock motor,, Please somebody help me! Can I somewhere find more info about wiring and colors of wires in Opel/Vauxhall cars or something to help me getting this right?
Space Ace
jrilla
Gold - Posts: 1,498
Posted: November 20, 2004 at 11:34 PM / IP Logged
For a 2001 Corsa, I show RED / yellow for lock and RED / blue for unlock (2 pulses) located behind the glovebox. Negative type.
for a 1994, Lock is BROWN / red and unlock is BROWN / white located in o/s kick panel (wherever that is)
DEI Techsoft only has 01 and 94 for the Corsa. Thats pretty random, but its something.
J Rilla
Owner/Installer
spaceace
Member - Posts: 8
Posted: November 21, 2004 at 6:14 AM / IP Logged
Thank you, 94 and the 99 Corsa is very similiar
Space Ace
spaceace
Member - Posts: 8
Posted: November 21, 2004 at 8:35 AM / IP Logged
I tried to connect this wires and nothing happened in the installing manual that came with the system, the manual tells me to connect the
green wire to up lock (BROWN / red)
the purple wire to down lock (BROWN / white)
and there are also Orange and White wires from the system
Orange---> +Door Switch Polarity Selection
White---> -Door Switch Polarity Selection,
Do i have to connect the white and orange wires to make this crap work??
Space Ace
jrilla
Gold - Posts: 1,498
Posted: November 21, 2004 at 8:45 AM / IP Logged
Did you test the wires to see if they are the lock wires? If they are negative then pulsing them by touching them with a fused wire that is connected to chassis ground will control them. If they are negative I would say then connect the white wire to chassis ground. I dont know the alarm, but that has got to be the way it works. Be sure to test the wires. You should use a Digital Volt Meter to test the wires though.
J Rilla
Owner/Installer
spaceace
Member - Posts: 8
Posted: November 21, 2004 at 9:07 AM / IP Logged
Ok I will try that,
Space Ace
spaceace
Member - Posts: 8
Posted: November 22, 2004 at 8:51 AM / IP Logged
Here is the installing manual can you tell me how I have to connect this crap to my Corsa, you sound like a pro so I think you will get this right
Keyless entry, problem -- posted image.
Space Ace
jrilla
Gold - Posts: 1,498
Posted: November 22, 2004 at 9:59 AM / IP Logged
Ok that only helps in that it tells me there are 6 wires we are working with. that means there are onboard relays that control the locks.
First you need to test the locck wires to find out if they are the correct wires and also to find out their switching type. If they are negative, then 2 of the 6 wires will go to ground and 2 will not get used. The other 2 will go to lock and unlock wires. If you can post the part of the manual where it describes what each wire does that will help.
I am guessing the locks are negative since the 94 and 01 were negative. So first go test them. Do you have a DMM?
J Rilla
Owner/Installer
spaceace
Member - Posts: 8
Posted: November 22, 2004 at 10:16 AM / IP Logged
I thecked them and it is negetive,,,
How do I connect it now,
Green to Unlock(BROWN / red)
Purple to Lock(BROWN / white)
and what then??
Space Ace
spaceace
Member - Posts: 8
Posted: November 22, 2004 at 10:17 AM / IP Logged
*THECKED I ment to say tested
Space Ace
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
