auto-start relay and starter kill relay
endubho
Member - Posts: 6
Posted: December 19, 2004 at 9:23 PM / IP Logged
what kind of relays do i need for auto start and starter kill?
is there only one kind for automotive?????as long as its 12VDC
KarTuneMan
Platinum - Posts: 7,056
Posted: December 19, 2004 at 10:24 PM / IP Logged
All of the remote start manufactures I have ever dealt with, have their own relays built in (for the remote start)   The only relays you might have to add will be for door lock or starter kill  spdt 30/40 amp relays are whats best to use. there are quite a few to choose from!   depending on how many you buy, they might cost a buck to a buck 50
Be careful....use a Digital multimeter  stay with name brands too,they come with fewer problems!!auto-start relay and starter kill relay - Last Post -- posted image.
auex
Platinum - Posts: 5,041
Posted: December 19, 2004 at 10:32 PM / IP Logged
There are many types of relays used, but the most common is the standard SPDT, single pole double throw relay. You can do just about anything you would need to do in a car by using these.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
