New Fiberglass trimming trick
Stlb5
Member - Posts: 27
Posted: December 20, 2004 at 6:54 AM / IP Logged
I'm sure some of you more seasoned glassers have a better way to do this, but I just figured this out this weekend.  I was always having problems trimming my enclosures after I had wrapped fleece and then glassed over it.  When ever I was trimming the edges and the speaker hole, I'd either go too far or not far enough and cut inside or outside the hole which meant I had to grind it down or repair it.  Well, this weekend I ran out of the blue fleece I normally use so I used some white stuff.  After I wrapped the fleece tight, I took a sharpy and drew a line around the outside edge and around the speaker hole.  After laying glass, I could still see the line and knew exactly where to trim!  Saved a ton of time.  My $0.02.
realitycheck
Silver - Posts: 751
Posted: December 20, 2004 at 9:02 AM / IP Logged
Good call man! Nice info!
JRoscoe
Member - Posts: 29
Posted: December 20, 2004 at 7:22 PM / IP Logged
I always wait until the glass i just about fully cured, then I just take a nice sharp razor and cut it out.  It works really well.
biker8018
Copper - Posts: 46
Posted: December 21, 2004 at 2:46 AM / IP Logged
dremel tool with a 1/8" drill bit.smooth quick and painless
realitycheck
Silver - Posts: 751
Posted: December 21, 2004 at 9:38 AM / IP Logged
Yeah I used the old dremel with the cutting wheel.  Didnt take no time, but hes saying he had trouble seeing where he needed to cut after he had glassed over it. So he did that so that he could see where to cut!
Stlb5
Member - Posts: 27
Posted: December 21, 2004 at 11:26 AM / IP Logged
yep, I use the cutting wheel too, but I think what he's saying is to use the drill bit and the MDF will guide you around only cutting the glass.  Does just a regular bit work, or do you need a spiral cut like a router?
mv2123
Member - Posts: 21
Posted: December 24, 2004 at 1:40 PM / IP Logged
damn i should get a dremmel does thing come in handy
wait , you hear something sparking?
Captanham
Silver - Posts: 365
Posted: December 24, 2004 at 4:15 PM / IP Logged
yea, you shouldn't be doing anything in this buiz without a dremel, they are a life saver, one of the best tools to have i think, my .02, haha
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Carbonb
Copper - Posts: 113
Posted: December 24, 2004 at 5:52 PM / IP Logged
Yeah dremels are nice. Since I use a dark grey fleece it's hard to write on it :P
I've been doing poor work lately since it's cold and I'm rushing my work ;(
Bah, anyways I glass'd a switch mount thing. I just need to sand it a bit and then carpet it :P
I like carpeting now for some reason.
mlazzaro
Member - Posts: 9
Posted: December 27, 2004 at 8:24 AM / IP Logged
i use a rotozip with the drywall side cutting bit it works great and is very fast. makes a lot of ichy dust thought so make sure u cover up
