adding domelight supervision
dyer
Copper - Posts: 206
Posted: December 22, 2004 at 4:13 PM / IP Logged
This shouldn't be that difficult so I have to be looking over something...but heres the deal. I'm installing a basic alarm/keyless entry system on a 2003 hyndai accent. The alarm is a 'K9 mundial 2'. The K9 doesn't have a domelight output, so how can i wire up a relay to make one work? I looked at the diagram on this site, but that requires a wire from the alarm that is hot when disarming...i don't think this K9 has such a wire. Any input would be great!
Dyer
Teamrf
Gold - Posts: 1,031
Posted: December 22, 2004 at 9:37 PM / IP Logged
You can use your unlock wire to trigger a relay causing your lights to come on.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Teamrf
Gold - Posts: 1,031
~The Rookie~
secureauto
Copper - Posts: 196
Posted: December 22, 2004 at 9:53 PM / IP Logged
When disarming the alarm do the parking lights have a delay? if so, use a relay to keep the domelight on. also put a diode on your parking light output, at the connection or before the relay, so when you turn on your lights the domelight doesnt come on.
ASE Certified
gcorrea
Silver - Posts: 436
Posted: December 24, 2004 at 7:01 PM / IP Logged
go to  the omega research web site and look at the install manual. all k-9 alarms have domelight supervision. my k-9 classic has a single wire hook up since it has a build in relay for this option. my wire on the alarm is GREEN/ violet.
gcorrea
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
