Blaupunkt trouble
mobile E
Copper - Posts: 217
Posted: December 23, 2004 at 10:21 PM / IP Logged
i have a blaupunkt santa monica cd30 cd player that im trying to install into my car and it wont power up.  I have checked all the fuses in the car and in the deck and there are no blown fuses.  I have all the wires hooked up but the ground.... Now here comes the tricky part... The sticker on top of the deck says that position 8 is the ground position...  but the harness has no black wire that comes out of position 8.... now i got this deck for free and i know it works because i saw it work in the car it came from it was an 88 300zx.. does it have a different grounding system or something? So i have tried sticking the ground wire strigght through the harness to the prong and that doesnt work either... did this deck die somewhere in the process of transferring it from car to car??  is there a way to check if the deck is still good??
Thanks guys
everything stolen :(
Workin on a new system :)
Blaupunkt trouble - Last Post -- posted image.
Peace in the middle east
KarTuneMan
Platinum - Posts: 7,056
Posted: December 23, 2004 at 10:33 PM / IP Logged
Usually with no ground...you can plug in the antenna and that will ground the deck. Try that?
geepherder
Platinum - Posts: 3,668
Posted: December 24, 2004 at 9:28 AM / IP Logged
Yes, the antenna will provide a ground.  Most decks have a threaded hole in the back where you can attach a piece of backstrap.  If there's no ground wire, you could run a wire from there to ground for a better ground.
97Pathy
Member - Posts: 46
Posted: December 24, 2004 at 9:57 AM / IP Logged
The whole chassis of the cd player is a ground, just run a wire from a screw on the back, to the ground wire in your car.
mobile E
Copper - Posts: 217
Posted: December 24, 2004 at 2:06 PM / IP Logged
ya ive tried that .... none of it is good and there is a screw thread on the back of the cd player chassis..... am i missing something... ??
Alpine Guy
Platinum - Posts: 2,478
Posted: December 24, 2004 at 10:41 PM / IP Logged
are you shure you have power, and ground for definate shure?  like you tested them all?
mobile E
Copper - Posts: 217
Posted: December 24, 2004 at 11:01 PM / IP Logged
ahh thank you very much fellas... there was a fuse hiding in the engine bay that had something to do with the stereo... (even though it said something about ECU!?!?) hmm go figure... and i never knew that you could use the antenna as a ground
thanks for you help...
