2001 blazer, 02 Impala
jaurora
Silver - Posts: 429
Posted: December 27, 2004 at 9:19 AM / IP Logged
My server is shut down and I cant get a tech sheet for these two vehicles.
Can someone help me out with a tech sheet.
Thankyou & happy holidays.
MECP certified (If it really means anything)
Jeremy
gfella2000
Member - Posts: 28
Posted: December 27, 2004 at 9:49 AM / IP Logged
2001 blazer
Wire/Function
Colour
Location/Description
Polarity
PASSIVE ANTI-THEFT YES PASSLOCK 2 SEE NOTES
12 VOLTS Red Ignition harness +
IGNITION Pink Ignition harness +
IGNITION 2 White Ignition harness +
ACCESSORY Orange Ignition harness +
STARTER Yellow Ignition harness +
TACH White At coil on motor AC
LOCK Lt.blue At module above driver's kickpanel +
UNLOCK White At module above driver's kickpanel +
DRIVER LOCK MOTOR Gray At relay block under dash +
DRIVER UNLOCK MOTOR Tan At relay block under dash* +
DOORPIN White** At courtesy light under dash** -
TRUNK PIN Common with doors
TRUNK RELEASE Black At release switch in dash -
FACTORY ARM Tan*** At BCM in front of center console -
FACTORY DISARM Lt.green At BCM in front of center console -
BRAKESWITCH White At switch above brake pedal +
PARKLIGHTS Lt.blue At light switch harness +
HORN Black At steering column harness -
CLUTCH SWITCH PURPLE / white At switch on top of clutch pedal TYPE 1
DRIVER WINDOW UP Dk.blue At switch in driver's door REV POL
DRIVER WINDOW DOWN Brown At switch in driver's door REV POL
PASSENGER WINDOW UP Blue or Blue/white At switch in driver's door REV POL
PASSENGER WINDOW DOWN Tan At switch in driver's door REV POL
LEFT REAR WINDOW UP Dk.green At switch in driver's door REV POL
LEFT REAR WINDOW DOWN Purple At switch in driver's door REV POL
RIGHT REAR WINDOW UP Lt.green At switch in driver's door REV POL
RIGHT REAR WINDOW DOWN Purple At switch in driver's door REV POL
HEADLIGHTS White At light switch harness +
REVERSE LIGHTS Lt.green At steering column harness +
DIMMER Dk.green or Gray At dimmer switch harness
VSS WIRE Dk.GREEN / WHITE**** VCM in right front engine compartment 4000ppm
KEY SENSE Lt.green Ignition harness -
DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash DATA
PASSLOCK DATA Yellow In 3 wire harness from ignition switch DATA
PASSLOCK GROUND ORANGE / black In 3 wire harness from ignition switch -
2001 blazer, 02 Impala -- posted image. Vehicle notes
PLEASE NOTE: Equipped with PASSLOCK II anti-theft system, see security diagram. For remote start installation, it will be necessary to pulse the TAN (driver's doorpin wire) to shut off the RAP system or the radio and accessories with stay on after the remote starter has shut down. Use you remote starter's rearm wire or any wire that provides a pulse after shutdown. SECOND IGNITION must be connected for remote start or the transmission computer will shut down ( engine light comes on ), and the vehicle will not shift properly.
* There is more than one wire of this color, please test carefully.
** There is a domelight override on the light switch. When this switch is turned on, the courtesy lights do not come on either. To insure proper protection of the doors, you will need to go directly to the Body Control Module located behind the dash in front of the center console. There you can find a TAN(driver's door), ORANGE(passenger door), BLUE/WHITE(rear doors) and PINK/BLACK (hatch). These wires are not affected by the override switch.
*** This is also the driver's doorpin wire, ground this wire with lock to arm the factory security. Also shuts down RAP system.
**** Pin-3 of the 24-pin BLACK connector.
gfella 20000000000
gfella2000
Member - Posts: 28
Posted: December 27, 2004 at 9:52 AM / IP Logged
Chevrolet Impala 2002
2001 blazer, 02 Impala -- posted image. Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarity
12 VOLTS Red Ignition switch harness +
IGNITION Pink Ignition switch harness +
IGNITION 2 Dk.green Ignition switch harness +
ACCESSORY Orange Ignition switch harness +
STARTER Yellow Ignition switch harness +
TACH White At coil on engine* AC
LOCK ORANGE / black Pin-B3 on C2 connector at BCM** -
DRIVER LOCK MOTOR Gray At under dash fusepanel****** +
DRIVER UNLOCK MOTOR Tan At under dash fusepanel +
DOORPIN SEE NOTES***
TRUNK PIN RED / black Pin-A11 on C2 connector at BCM**** -
TRUNK RELEASE Black or Lt.blue SEE NOTES***** -
FACTORY ARM SEE NOTES*******
FACTORY DISARM Lt.green Pin-B3 on C3 connector at BCM**** -
PARKLIGHTS Lt.blue At light switch harness -
HAND BRAKE Lt.green Pin-B6 on C3 connector at BCM**** -
HORN Black Pin-B5 on C1 connector at BCM**** -
DRIVER WINDOW UP Dk.blue At master window switch REV POL
DRIVER WINDOW DOWN Dk.brown At master window switch REV POL
PASSENGER WINDOW UP Lt.blue At master window switch REV POL
PASSENGER WINDOW DOWN Tan At master window switch REV POL
LEFT REAR WINDOW UP Dk.green At master window switch REV POL
LEFT REAR WINDOW DOWN Violet At master window switch REV POL
RIGHT REAR WINDOW UP Lt.green At master window switch REV POL
RIGHT REAR WINDOW DOWN Violet At master window switch REV POL
HEADLIGHTS Yellow At light switch harness +
REVERSE LIGHTS Dk.blue Pin-B6 on C1 connector at BCM**** -
DIMMER Gray At light switch harness +
VSS WIRE Dk.green Pin-B5 on C3 connector at BCM**** 4000ppm
KEY SENSE Lt.green Pin-B1 on C3 connector at BCM**** -
PLEASE NOTE: This vehicle is equipped with GM's PASSLOCK II passive anti-theft system. Please refer to the PASSLOCK II bypass diagram before any remote start installation. Also note that the factory alarm will disarm automatically on remote start with a properly installed PASSLOCK II bypass.
* On the 3.4L the coil is found at the top rear of the engine. On the 3.8L the coil is on the front right side of the engine. (See exploded views).
** This single wire doorlock system uses ground to unlock and ground through a 480-ohm resistor to lock. This wire is found at the BCM above the driver's kickpanel. See the DOORLOCK diagram for instructions.
*** DK.BLUE for driver's door and BLUE/WHITE catches all other doors. Both wire are found at the BCM above the driver's kickpanel. See the Body Control Module diagram for exact pin-out locations.
**** The BCM is located under the drivers side of the dash above the kickpanel. See the Body Control Module diagram for exact pin-out locations.
***** BLACK is the ( + ) trunk release relay output and is found at pin-A7 on the pink 16-pin C3 connector. LT.BLUE is the ( - ) trunk release relay input and is found at pin-A2 on the gray 24-pin C2 connector
****** You must use a 56-Kohm resistor in line with you connection to this wire for keyless upgrade.
******* The factory alarm system can be armed by pulsing the DK.BLUE driver's doorpin wire ( - ) at the same time as the lock pulse to the doorlock wire. The DK.BLUE wire is located at pin-A8 on the gray 16-pin C3 connector at the BCM above the driver's kickpanel. See the Body Control Module diagram for exact pin-out locations
gfella 20000000000
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
