2004 chevy tracker remote starter
sherman525
Posted: December 28, 2004 at 9:29 AM / IP Logged
Im installing a DesignTech remote starter in a 2004 Chevy tracker.  I am extremely unclear on every wiring diagram I find concerning the ignition switch harness.  Here's what I see:
Starter - blk/yel to blk/red
Ignition - blk/wht to blk/blu
Ignition 2 - blk/wht to blu/blk
Accessory - yel/blk
Accessory 2 - blue (not necessary for remote start?)
Starter's no problem.
Notice Ignition 1 and 2 are blk/wht.  There is only one blk/wht wire in the ignition switch harness.  All the documentation says that the wires change color at a plug.  On one end of the harness is the key switch, and the other end is connected to a panel where all the other harnesses in the whole car plug into.  Do I have to search through all the wires on the other side of that plug panel to find the blk/blu and blu/blk wires?  Also, how does one blk/wht wire turn into 2 wires that are supposed to have different signals on them by going through just a plug?
The install guide describes the funtionality of the wires.  The accessory wire should be off in the key off position, on in the acc postion, on in the run postition, and off in the start position. Am I right?  In the tracker, the yel/blk wire is off in the acc position! In fact, it behaves like the ignition 2 should.  Why?
So those of you who have done an remote starter install on a 2001-2004 (wiring should be the same) chevy tracker, please help!  I guess the most important thing for me to know is what the deal is with ignition 1 and ignition 2.
thank you very much
draasch
Gold - Posts: 2,172
Posted: December 28, 2004 at 12:19 PM / IP Logged
Make:   Chevrolet
Model: Tracker
Year:    2003
This Database Was Last Updated On:    9/16/2004
Index #: 6377
Alarm
Constant 12 volts WHITE/ YELLOW IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK/ RED IGNITION SWITCH HARNESS
Dome Light BROWN / GRAY (-) AT DOOR SWITCH
Trunk Pin Switch
Parking Lamp RED / YELLOW (+) AT VEHICLE FUSE PANEL
Power Lock PINK DRIVERS KICK PANEL #201
Power Unlock PINK/BLACK DRIVERS KICK PANEL
#201 See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal BROWN / WHITE AT IGNITION COIL
Ignition #2
Ignition #3
Accessory YELLOW/BLACK IGNITION SWITCH HARNESS
Neutral Safety
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Light LIGHT GREEN IGNITION SWITCH HARNESS
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sherman525
Posted: December 28, 2004 at 12:49 PM / IP Logged
Thanks.  This pretty much confirms that the yel/blk wire is the accessory wire, even though I still don't know why it doesn't have 12V when the key is in accessory.
Ok, so I know the starter, I know the accessory, and I have one unused wire (wht/blk) left in the harness.  But the remote starter module is looking for 2 more wires, ignition 1 and ignition 2.  Any ideas?
gfella2000
Member - Posts: 28
Posted: December 28, 2004 at 1:10 PM / IP Logged
Chevrolet Tracker 2004
2004 chevy tracker remote starter - Last Post -- posted image. Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarity
12 VOLTS WHITE/ yellow Ignition harness +
IGNITION BLACK/ white Ignition harness +
ACCESSORY Yellow/black Ignition harness +
STARTER BLACK/ red or BLACK / YELLOW Ignition harness +
TACH Brown At ECM below glove compartment AC
LOCK Pink In driver's kickpanel +
UNLOCK Pink/green In driver's kickpanel +
DOORPIN BLACK/ red Passenger pinswitch -
TRUNK PIN Common with doors
TRUNK RELEASE Manual release
BRAKESWITCH GREEN / WHITE At switch above brake pedal +
PARKLIGHTS RED / yellow At relay in dash +
HAND BRAKE RED / black or Purple DRL module on left of steering column -
HORN GREEN/ blue At steering column harness -
CLUTCH SWITCH BLACK / YELLOW At switch on top of clutch pedal TYPE 1
DRIVER WINDOW UP Dk.blue At switch in driver's door REV POL
DRIVER WINDOW DOWN Brown At switch in driver's door REV POL
PASSENGER WINDOW UP Blue or Blue/white At switch in driver's door REV POL
PASSENGER WINDOW DOWN Tan At switch in driver's door REV POL
HEADLIGHTS Red At light switch harness -
REVERSE LIGHTS Lt.green At steering column harness +
DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash DATA
gfella 20000000000
kgerry
Platinum - Posts: 3,455
Posted: December 28, 2004 at 1:35 PM / IP Logged
keep in mind although the unit may be capable for powering a second ignition, this is only needed if the vehicle itself requires it... it appears you dont need to worry about ign 2.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sherman525
Posted: December 29, 2004 at 7:17 AM / IP Logged
Well, I tried without hooking up any ignition 2, and still nothing.  The unit is supposed to go through a initialization sequence.  First I turn on the unit, then open the hood, then press the brake and see the dash lights light up, then turn the key on and shift into drive then back to park.  When I do this, the dash lights don't come on when I press the brake and the thing never initializes.
Any Ideas?  Can anyone with a tracker with remote start working let me know how you did the wiring?  I appreciate all your help.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
