2004 Isuzu Axiom bypass module
jayyzr
Copper - Posts: 114
Posted: December 28, 2004 at 5:22 PM / IP Logged
Is there any type of bypass module needed to put a remote starter on a 2004 isuzu axiom...
Taking It 1 Wire @ A Time...
swamprat323
Gold - Posts: 1,335
Posted: December 28, 2004 at 5:40 PM / IP Logged
For a 2003-2004 use a 556U.
gfella2000
Member - Posts: 28
Posted: December 28, 2004 at 5:45 PM / IP Logged
Isuzu Axiom 2004
2004 Isuzu Axiom bypass module - Last Post -- posted image. Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS White Ignition switch harness +
IGNITION BLACK / YELLOW* Ignition switch harness +
ACCESSORY BLACK/ red* Ignition switch harness +
STARTER BLACK/ white* Ignition switch harness +
TACH BLACK/ red On black connector in Driver's kick AC
LOCK Lt.GREEN/ red At alarm module behind glovebox -
UNLOCK RED / blue At alarm module behind glovebox -
DOORPIN BLACK/ blue At alarm module behind glovebox -
HOODPIN GREEN/ red At alarm module behind glovebox -
TRUNK PIN Common with doorpin
FACTORY ARM Lt.green At alarm module behind glovebox -
FACTORY DISARM Blue / YELLOW At alarm module behind glovebox -
BRAKESWITCH Red At switch above brake pedal +
PARKLIGHTS GREEN/ red In driver's kickpanel +
HORN Green At steering column -
VSS WIRE BLACK / YELLOW Behind radio
KEY SENSE Pink/blue* Ignition switch harness +
2004 Isuzu Axiom bypass module - Last Post -- posted image. Vehicle notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER based passive anti-theft system. A product may be available to bypass the system without the use of a key. Contact your supplier to find out. If one of these kits is not available to you, please refer to the appropriate security diagram before any remote start installation.
* There is a connector on the steering column through which the wires change color. The wires listed are on the key side of the connector.
gfella 20000000000
jayyzr
Copper - Posts: 114
Posted: December 28, 2004 at 5:57 PM / IP Logged
Thanks for both of your replies
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
