What comes first
cubinbob
Member - Posts: 43
Posted: December 30, 2004 at 4:46 PM / IP Logged
someon just told me that i am mixic my fiberglass mix wrong. He said that i have to put in the resin first then the catalyst. He said if i do it wrong it might explode. What do yall guys think. Need expert opinion. Thanks
dowmace
Member - Posts: 23
Posted: December 30, 2004 at 5:46 PM / IP Logged
he sounds like a moron, if you mix fiberglass resin and mekp incorrectly it will either A. not ever harden or B. Gel immediately or C. just take forver to harden.
As long as you are putting in the correct amounts of resin and Mekp then you are safe from an explosion, whoever told you that doesn't know anything about FG apparently
bluetruck
Copper - Posts: 115
if you mix it to the wrong proportion it will not work but i do not think it will explode. always mix to the manufacturers recomendation. hope this helps.
auex
Platinum - Posts: 5,041
Posted: December 30, 2004 at 6:19 PM / IP Logged
Explode, hell no. Smoke, yeah. I have never seen it "flame up" unintentionaly.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
cubinbob
Member - Posts: 43
Posted: December 30, 2004 at 6:57 PM / IP Logged
ok thanks for clearing it up. I just did not know if he is right. I hate to do it wrong and end up in the hospitall knowing that he was right. Thanks again and i have a great new year : dowmace, bluetruck, auex and the rest of the the12volt forum.
cubinbob
Member - Posts: 43
ok thanks for clearing it up. I just did not know if he is right. I hate to do it wrong and end up in the hospital knowing that he was right. Thanks again and i have a great new year : dowmace, bluetruck, auex and the rest of the the12volt forum.
Alpine Guy
Platinum - Posts: 2,478
Posted: December 30, 2004 at 8:44 PM / IP Logged
I mixed a crap load of hardener to a little bit of resin and it lit the plastic container on fire, , but that was after a few min in the gel phase.
dowmace
Member - Posts: 23
Posted: December 30, 2004 at 8:47 PM / IP Logged
thats true if you have a crap load of Mekp and not very much resin it can actually light whatever it's in on fire, I know I've melted the plastic lid that comes on quarts of resin with too much hardener before
bluetruck
Copper - Posts: 115
Posted: December 31, 2004 at 6:34 AM / IP Logged
*goes to garage to try this for himself!*
auex
Posted: December 31, 2004 at 11:50 AM / IP Logged
Don't forget the smoke is TOXIC!!!
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
