2000 grand cherokee remote start
dadz
Member - Posts: 33
Posted: January 03, 2005 at 12:56 PM / IP Logged
I am doing a remote start on a 2000 jeep grand cherokee and i can't find my wiring diagram for it, can anyone help me out?
Thanx
Craig3708
Copper - Posts: 155
Posted: January 03, 2005 at 1:24 PM / IP Logged
CHEROKEE           1999 - 2001
WIRE COLORSLOCATION
12 VOLTS CONSTANT
RED and PINK/BLACK (+)
IGNITION SWITCH HARNESS
IGNITION 1DARK BLUE (+)IGNITION SWITCH HARNESS
IGNITION 2BLACK/ WHITE (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER BLACK/ ORANGE (+)IGNITION SWITCH HARNESS
STARTERYELLOW (+)IGNITION SWITCH HARNESS
PARKING LIGHTSBLACK / YELLOW (+)@ HEAD LIGHT SWITCH
DOOR TRIGGERYELLOW (-) IN DRIVERS KICK PANEL in a GREY 2-Pin plug
DOME LIGHTUSE DOOR TRIGGER
POWER DOOR LOCKORANGE / VIOLETIN DRIVERS KICK PANEL (TYPE A)
POWER DOOR UNLOCKPINK/VIOLETIN DRIVERS KICK PANEL (TYPE A)
TACH SENSORGREY@ PCM, BLACK Plug    See NOTE *1
BRAKE
WHITE/ TAN (+)@ SWITCH ABOVE BRAKE PEDAL
HORN
BLACK/ RED (-)
@ STEERING COLUMN HARNESS
FACTORY DISARM
GREEN/ ORANGE (-)
ANTI-THEFTCHRYSLER SENTRY KEY (GREY IGNITION KEY ONLY)TRANSPONDER (REQUIRES PART 791 and EXTRA IGNITION KEY)
NOTE *1     the PCM is located on the DRIVERS SIDE INNER FENDER near the Radiator support.
KarTuneMan
Platinum - Posts: 7,056
dadz
Member - Posts: 33
Posted: January 11, 2005 at 9:25 AM / IP Logged
Need wiring diagram to install remote start on 2000 grand cherokee..
thanx
thepencil
Gold - Posts: 1,526
Posted: January 11, 2005 at 2:43 PM / IP Logged
2000 Grand Cherokee wiring diagram
Be careful whose advice you buy, but be patient with those who supply it.2000 grand cherokee remote start -- posted image.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
