install related problem?
sroth140
Silver - Posts: 513
Posted: January 08, 2005 at 2:18 AM / IP Logged
i installed a  deck and sub/amp setup in a 1994 chevy 1500 today.  about 45 min later i got a call at work from the customer saying the lights went out on the way home, wipers stopped, and the battery sad 9 volts.
i about sh*t.
i used a GM battey tap at the battery.... so thats basic enough.  i ran (fused) through the firewall (grommet) to the amp and grounded it from there.  so thats all normal.
i did the check in and out list, everythings was fine except for the check engine light on the dash and some minor broken trim peices.  i drove it out with the new deck on a local radio station and the subs thumpin.  i saw no voltage or battery indicator lights on and i even remember playing with the dimmer for the dash lights when i was getting out to make sure the interior lights were working (non functional lights with the door trigger.
all  i can think of is the alternator taking a dump.  i dont know if it was original (well over 100k miles).  maybe the new load from the amp stressed it while it was on the edge.  it sounds like the vehicle ran off the battery for a few miles then failed from not chargning.
any input?
MECP certified installer
wheelerdr
Copper - Posts: 337
Posted: January 08, 2005 at 6:42 AM / IP Logged
That sounds about right, I have some installs with the alternator taking a dump after an amp, Sometimes the alt is about to go and then the added stress of an amp does it. have him take the alt to get checked out. and just explain it to him that this happens.
jeffchilcott
Platinum - Posts: 2,483
Posted: January 08, 2005 at 11:42 AM / IP Logged
wow,   I havent had this happen yet..Knock on wood.    But it really sounds like the alternator is going to the car store above.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
KarTuneMan
Platinum - Posts: 7,056
Posted: January 08, 2005 at 12:02 PM / IP Logged
Ifd there are no blown fuses.....and you can charge the battery back up and geter runnin for a bit......alternator poop is correct.  Just out of curiosity, what s the amp and sub setup?
sroth140
Silver - Posts: 513
Posted: January 08, 2005 at 1:39 PM / IP Logged
the amp/sub was really worth all the trouble. a lightening audio 4ch amp and two pioneer 10"s. whoopie.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
