Kenwood KDC-MP8017
showngo2000
Copper - Posts: 61
Posted: January 15, 2005 at 1:16 PM / IP Logged
I recently purchased this cd/mp3 used.  After bench testing it, I have found a few problems.  Whether in tuner or cd mode, the volume on this is barely able to be heard.  If I put my hear really close to the speaker, I can hear it.  Does this mean that an internal amp or pre-amp of some sorts is blown?  How do I know where to find it?  PLEASE HELP!
esmith69
Gold - Posts: 1,511
Posted: January 15, 2005 at 9:34 PM / IP Logged
Try using the preouts for your test bench's inputs and see if you get sound then.  If so, then either the internal amp is busted, or the onboard amp is disabled (some head units have this kind of option in their settings menus).
Kenwood's support site lists, among others, Pacific Coast Parts as a distributor of replacement parts for their products.  If you go to their site you should be able to enter in your head unit's model number and see a listing of available parts.
Ethan
Donate to the12volt.com
showngo2000
Copper - Posts: 61
Posted: January 17, 2005 at 6:05 PM / IP Logged
I tried your advice, and still no sound.  So I guess I should look into selling it or replacing the onboard amp?  Thanks for the advice!
esmith69
Gold - Posts: 1,511
Posted: January 17, 2005 at 6:54 PM / IP Logged
Can you hear ANYTHING when the preamp outputs are connected?  I know you said that with the speaker outputs connected, you could just barely hear a tiny bit if you put your ear up to the speaker.
With only the preouts feeding your testbench an input signal, I'd expect there to either be full/normal output, or absolutely none at all.  It's certainly possible that both the preouts and internal amp are bad, but usually it'd be one or the other.  If both those components are bad, I doubt you'd be able to get anyone to buy it.
Ethan
showngo2000
Copper - Posts: 61
Posted: January 19, 2005 at 7:27 AM / IP Logged
no, i can hear nothing, any of the time, with any connection.
kgerry
Platinum - Posts: 3,455
Posted: January 19, 2005 at 6:57 PM / IP Logged
so you're saying you had nothing when you hooked the pre-outs to an outboard amp?? then it wont be the built in O/P IC... sounds like it's latched in a mute mode.... or possibly the EVC ( Electronic Volume Control) IC
are you sure about the pre-outs not working either??
lastly, meter the remote out lead for voltage... what do you have?   sometimes these units will go mute when you smoke the remote turn-on transistor.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
