second ignition wire?
bluehoe
Member - Posts: 11
Posted: January 20, 2005 at 7:14 PM / IP Logged
hey guys i ahvea 2000 tahoe and i installed a viper 791xv w remote start and when ever i remote start it the check engine light comes on and the tranny wont shift correctly. my first thought was that it was a bad connection on the the second ignition wire, but i remade the connection and the problem persists. thanks
DanDan
Copper - Posts: 125
Posted: January 20, 2005 at 7:29 PM / IP Logged
Make absolutely sure that your powering the white second ignition wire. And not only that make sure it acts exactly like the regular ignition wire while the vehicle is remote started. Which means the white wire must have power while the vehicle is cranking. Do not remote start the vehicle and drive it until you fix the problem or you will be buying a new tranny.
DanDan
thepencil
Gold - Posts: 1,526
Posted: January 20, 2005 at 7:32 PM / IP Logged
CHEVROLET, TAHOE, 2000, Second Ignition
To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Check your wiring again against this. Make sure your jumper on the remote starter unit is set on second ignition.
Be careful whose advice you buy, but be patient with those who supply it.second ignition wire? - Last Post -- posted image.
bluehoe
Member - Posts: 11
Posted: January 20, 2005 at 7:41 PM / IP Logged
this was the first security system i have ever installed so im not to sure what you mean by " make sure your jumper on the remote start unit is set on second ignition"
meltingplastic
Copper - Posts: 225
Posted: January 20, 2005 at 7:52 PM / IP Logged
with that unit u can set the 2nd ignition to be 2nd acc if needed.. so make sure its set for ignition and not accessory
Driving a Bagged, Caddied 02 s10
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
