CLifford Matrix Starter disable on Nissan
srusin1
Copper - Posts: 86
Posted: January 22, 2005 at 6:26 PM / IP Logged
How does the starter disable get wired up to a Nissan with two starter wires?
secureauto
Copper - Posts: 196
Posted: January 22, 2005 at 8:42 PM / IP Logged
You can normally use the thicker of the 2, but just in case,let us know which car it is so we can provide you with the correct info.CLifford Matrix Starter disable on Nissan -- posted image.
ASE Certified
metaverse
Copper - Posts: 210
Posted: January 22, 2005 at 8:55 PM / IP Logged
only one is the starter wire..the other is a starter cold circuit trigger..it tells the ECU to activate cold fuel mapping after getting feedback from the coolant temps sensor.
You will only connect starter disable to the starter wire going to the starter, the first starter wire..the wire that disables the starter from turning over. Ignore the second starter wire for disable (not for starting)
srusin1
Copper - Posts: 86
Posted: January 22, 2005 at 9:03 PM / IP Logged
Which wires from the MAtrix 3.5 go to the starter wires?
metaverse
Copper - Posts: 210
Posted: January 23, 2005 at 12:20 AM / IP Logged
Look at your other post "Nissan Sentra Clifford 3.5 wont start" No point continuing this thread when I posted the answer there..
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
