window modules in a 02 chevy avalanche?
Blackiewrx
Copper - Posts: 56
Posted: January 28, 2005 at 10:51 AM / IP Logged
Is their anything wierd about them?? can i catch all four windows in the driver door, or do i have to run wires out of each door? thanks.
03 wrx stage 4
stackrat
Posted: February 01, 2005 at 10:07 PM / IP Logged
Bump (I'm interested too)
I haven't tried http://www.chevyavalanchefanclub.com/ yet, but I will.
CBill
Member - Posts: 28
Posted: February 02, 2005 at 1:18 AM / IP Logged
I have a Chevy 1995 S10 Blazer 4x4 and I installed the windows module in mine and hooked them all to the master windows panel in the driver door to all 4 windows and both module (one module for 2 windows up/down and one for both front windows and one for both rear windows) are located in the dashboard near the driver door .. had to run all 16 wires thur the door rubber boot along side the actual windows and powerlock wiring .. my boot was big enough to accept another 16 wires thru it so it wasn't too hard to snake 16 more wires into the driver door ..
On my Blazer the slave windows switches at each of the doors is only a bridge to the master switch so those slave switch is not part of the circuit until you flip it in either direction that why it was easy to catch all at the master switches since you are connect directly to the each power windows motor from there.
I am pretty sure Chevy made all thier car this way unless they change it later year that I am not aware of ..
Bill
slammedb5
Copper - Posts: 103
Posted: February 02, 2005 at 2:39 AM / IP Logged
You should be able to catch all 4 in the driver's door. Just read the 530t? instructions for auto(one touch) windows.
EK Civic
security
no audio
Uniqueauto
Copper - Posts: 73
Posted: February 02, 2005 at 8:04 AM / IP Logged
No, on that certain truck you have to go to every door and wire the window wires.
CBill
Member - Posts: 28
Posted: February 02, 2005 at 10:47 AM / IP Logged
Oh .. I see .. how come? is it using a relay or a module at each windows?
Bill
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
