Blown Fuse?
dh2777
Member - Posts: 8
Posted: February 02, 2005 at 10:00 PM / IP Logged
I recently installed a security system, and during the install at one point a live wire touched the frame of the car. This caused a 50amp fuse under the hood to blow, which I replaced. The problem is that my head unit dosent work anymore. The buttons light up when i turn my headlights on, and it will still eject cds, but it will not come on. I looked at all the fuses under the hood, in the drivers kick panel and the in line fuses in back of the unit, but none appear to be blown. Does anyone know what my problem might be? Thanks in advance.
-Dietich Hoefner
1995 Honda Accord
bullman96
Silver - Posts: 294
Posted: February 02, 2005 at 10:53 PM / IP Logged
a:what kind of head unit is it? b:check the hu for blown fuses. some have it inline on the batt wire, some in the back, and on occasions inside of it. if you can open it up without breaking warranty check for fried components in it
dh2777
Member - Posts: 8
Posted: February 02, 2005 at 11:14 PM / IP Logged
I have a Clarion ProAudio DXZ545MP. It does have in-line fuses, I checked them and they seem to be fine. Thanks
Javelin3o4
Copper - Posts: 239
Posted: February 03, 2005 at 2:17 AM / IP Logged
I'd use a multimeter and check the power directly at the back of the deck for 12v ignition and the 12v constant. if you got both and the fuse on the deck is find then there is a problem with the deck, if one doesnt show power than either the fuse is blow, or the circuit is damaged some how, and you will have to repair the circuit or run new power wires to the deck.
Jay T
Copper - Posts: 169
Posted: February 03, 2005 at 10:21 AM / IP Logged
Sounds like you have Constant but no Acc. power.   Check you cars stereo fuse in the fuse box. if you're wired through the harness
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
