2003 Dodge Caravan Radio Wiring
caravan03
Posted: February 05, 2005 at 6:14 PM / IP Logged
Wondering if someone has a 2003 Dodge Caravan stereo wiring diagram.  I purchased the van recently with an aftermarket stereo in it but wanted to go back to the factory deck.  The guy that did the aftermarket install cut off the orginal harness of the van.  I purchased the oem harness and installed every wire but I don't know what a white wire with a purple stripe is for I also have two extra wires in the harness that I bought a brown one and a white with red stripe.  I know that one goes to the one in the van but which one??  Any help would be great.  The stereo works fine as is but I hate leaving something not done right.
ippy98
Member - Posts: 25
Posted: February 05, 2005 at 11:56 PM / IP Logged
Radio 12v
      gray/red
      radio harness
Radio Ground
Radio Ignition      blue/pink       +       radio harness
Radio Illumination      ORANGE / tan       +       radio harness
Factory Amp Turn-on
Power Antenna
LF Speaker +/-      green - grn/brn             radio harness
RF Speaker +/-      gray - gry/brn             radio harness
LR Speaker +/-      grn/blu - grn/org             radio harness
RR Speaker +/-      gry/blu - gry/org             radio harness
hotwaterwizard
Silver - Posts: 1,350
Posted: February 06, 2005 at 1:55 AM / IP Logged
Dodge General WIRING PINOUTS
DESCRIPTION             OEM COLOR         STANDARD
Battery / Memory           Red                         Yellow
Ignition / Accessory      Red / White            Red
Ground                            Black                       Black
Power Antenna              Yellow                     Blue
Amplifier Turn On          N/A                           Blue / White
Illumination                     Orange / White     Orange
Dimmer                           N/A                          Orange / White
Front / Right +                 Purple                    Gray
Front / Right -                  Purple / Yellow     Gray / Black
Front / Left +                    Green                     White
Front / Left -                     Green / Yellow      White / Black
Rear / Right +                  Blue / Red             Purple
Rear / Right -                   Blue / White          Purple / Black
Rear / Left +                     Brown                    Green
Rear / Left -                      Brown / Yellow     Green / Black
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
caravan03
Posted: February 06, 2005 at 12:24 PM / IP Logged
Thanks for the replies!
There was one wire that was cut in the oem harness that actually turns the exterior lights on, turns the low fuel guage on and makes the van ding when I put a test light on it.   I can't beleive someone would have cut the harness like this everything seems to work fine on the van and the stereo works fine.
Great forum!2003 Dodge Caravan Radio Wiring -- posted image.
benjammin74
Member - Posts: 24
Posted: February 07, 2005 at 12:00 AM / IP Logged
be careful with your test light.. or "bag popper" as I like to refer to them. your van has many sensitive circuits and the wiring should only be tested with a multimeter!
car audio pays my bills...
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
