- horn wire on a 1989 Toyota Celica GTS
Mike_89gts
Member - Posts: 42
Posted: February 08, 2005 at 8:14 PM / IP Logged
Hello folks! - Here's the deal...
I'm looking for the - horn wire on the steering column harness and
it seems it's not there. ???
I'm suppose to be looking for a green wire - there's a little tiny one inside the steering wheel that plugs into the padded thing in the front and when you push the pad it sends out a ground.
Shouldn't there be a green wire on the backside of the steering
wheel running down the column? I found what looks like a lighter green one but it's got a constant ground. That wouldn't be it???
- I can't exactly run a wire into my steering wheel - it'll get all tangled after turning the wheel a few times. ;)
Any ideas???
Thanks in advance.
Mike ‘89GTS
mo12v
Posted: February 08, 2005 at 10:26 PM / IP Logged
I have:
OEM HornGREEN/ BLUE (-)STEERING COLUMN HARNESS
MO
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
