'98 Taurus Horn
skycruzr
Member - Posts: 7
Posted: February 12, 2005 at 8:24 AM / IP Logged
I installed a remote start on a '98 Taurus w/ little or no problem except for the horn.  I believe I found the proper wire, but it doesn't work.  Do I need a relay for this, or will it depend on the output?  R/S is EZ-2500 from Commando.  Thanks!
skycruzr
KarTuneMan
Platinum - Posts: 7,056
Posted: February 12, 2005 at 1:07 PM / IP Logged
Blue at the column....you might need a relay.....do you own a power probe, or multimeter?
Make sure it shown ground, with the DMM, then hit it with a solid ground.....HONK, no honk?
If you can ground it and HONK it, and the alarm does NOT....use a relay
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
