2 dvc 6 ohm and which amp?
jonj0n1
Member - Posts: 16
Posted: November 02, 2002 at 10:17 PM / IP Logged
ok i have searched the forums and i couldn't find the answer to my question.
i have 2 jl audio 12"w6 dual 6ohms 300 watt RMS each. i am looking for an amp that can run these two subs. if i run them in series it will result in 3 ohms. and if in parallel it would be 1.5ohms (correct me if im wrong)i been looking for some different types of amps and they are the jbl bp600.1 rated at 600w @ 2ohms. how many ohms should i setup my subs ? 1.5 or 3ohms? and one more question, will any amp that is rated at 2 ohms xxxwatts work with that setup also? thanks
http://manuals.harman.com/JBL/CAR/owner%27s%20manual/bp_om.pdf
jeffchilcott
Platinum - Posts: 2,483
Posted: November 03, 2002 at 7:21 PM / IP Logged
your resistance is wrong....if you run them in parallel form the 2 subs in parralel  will still have a 6 ohm load.....if you run the 2 subs in series you will have a 3 ohm load......If you are using DVC  (dual voice coil) subs    you can wire each sub to 6 ohms or 3 ohms.......thus giving you  a 6 ohm a 3 ohm or a 1.5 ohm load
(2) 6ohm subs in series are a 3 ohm load
(2) 3 ohm subs in series are a 1.5 ohm load
(2) 6 ohm subs in parallel are a 6 ohm load
(2) 3 ohm subs in parallel are a 3 ohm load
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jonj0n1
Member - Posts: 16
Posted: November 04, 2002 at 12:51 AM / IP Logged
well ok i got this from the jlaudio website....btw mines are dvc's. i have the coils wired in parallel.
http://www.jlaudio.com/subwoofers/pdfs/8-12W6_BDS.pdf
still haven't my question, if an amp is rated 600watts at 2 ohms. and if my speakers were 300watt each @ 6 ohms. what would be the best way to wire up my speakers to the amp. series/parallel? thanks a bunch
Sound Pressure
Silver - Posts: 711
Posted: November 04, 2002 at 1:19 AM / IP Logged
Jonjon1 you are correct with the ohm load config. I have my 2 12w6 hooked up in a parallel config. giving me a 1.5 load on a ps series kenwood. Not the best amp but I was surprised with the remarkable pounding sound that it gave me. I have heard good things with that JBL amp that you are talking about. I have not heard that particular one, but it should work out just fine. I had a couple of Orions that were stolen but they were great! They went as low as a .25 ohm load stable. So answering the other question if you had more subs with one amp depending on all you had ofcourse then I would hook it up in series. If only two subs then I would use parallel.
Sound Pressure
jonj0n1
Member - Posts: 16
Posted: November 04, 2002 at 8:35 PM / IP Logged
cool thanks Sound Pressure for you advice. also if an amp was rated at 2ohm stable can i still hook up my speakers to it if my ohms were 1.5?
Sound Pressure
Silver - Posts: 711
Posted: November 06, 2002 at 11:38 PM / IP Logged
No problem glad to help.
You will put some stress on the amp but not much!
Sound Pressure
Reeceddogg
Copper - Posts: 329
Posted: November 07, 2002 at 9:16 PM / IP Logged
I wouldn't go below the manufactures recomended resistance.  When you check it with a multimeter you'll notice that the subs will actually pull less than 3 or the 1.5 ohms. If you wire them in series pulling a 1.5 ohm load look for an amp that can handle atleast 1 ohm.  Or if you go in parallel try a power bd500
jonj0n1
Member - Posts: 16
Posted: November 08, 2002 at 8:15 PM / IP Logged
hey thanks for all the advice. i think ill be searching for an amp that will be stable at about 1ohm. maybe the orion hcca 250g4.
jeffchilcott
Posted: November 09, 2002 at 10:44 AM / IP Logged
I currently have a orion hcca 225 for sale......i might have a 250 in a week or so....it has been used and am looking for about $300 on it.......it has only been used for about a month,  i have changed from that to 2 memphis 1000d's     let me know if you would want it,
jeffchilcott@yahoo.com
2007 World Record
jonj0n1
Member - Posts: 16
Posted: November 10, 2002 at 12:13 AM / IP Logged
hey jeffchilcott, im kinda considering a class D amp now. i dont want to suck up too much power from my batt/alt. and 300 bucks is a lil over my budget. but thanks
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
