nissan remote start problems
Snowjoe69
Posted: February 26, 2005 at 5:28 PM / IP Logged
I have installed a Performance Tecknique Alarm System with remote start onto a 2004 Nissan Altima. Everything on the system works fine except the remote start. I was able to start the car about nine times in a row at first then once the morning. Untill recently I found out that there is a  second starter wire that needed to be hooked up. How should this wire be connected with only one output start wire from the alarm system? And does this nissan need an alarm bypass for the key? I have not been able to get it started since install. Please Help!! nissan remote start problems -- posted image. Thank You.
                                  Joe
Joe
KarTuneMan
Platinum - Posts: 7,056
Posted: February 26, 2005 at 6:02 PM / IP Logged
use the output (starter) to control another relay, to feed the second starter.fuse the second starter reay properly.
Yes you need a bypass
http://www.bypasskit.com/
radkonn
Copper - Posts: 73
Posted: February 26, 2005 at 7:11 PM / IP Logged
I had the same question a month ago about the second starter wire. Here is how I wired it up in my Nissan Frontier Crew Cab.
http://www.commandocaralarms.com/2ndstarterwire.asp
Second Starter Wiring
radkonn
Copper - Posts: 73
Posted: February 26, 2005 at 7:20 PM / IP Logged
radkonn
Copper - Posts: 73
Posted: February 26, 2005 at 7:22 PM / IP Logged
Try my second reply link. I wish the had an edit feature.
Snowjoe69
Posted: February 26, 2005 at 9:27 PM / IP Logged
Thanks a lot guys, I'll try this stuff out and see what happens.
Joe
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
