how should i do this?
projectprotege
Copper - Posts: 112
Posted: March 09, 2005 at 3:34 PM / IP Logged
ok i have a rockford fosgate 1000a2 amp and im running 4 rockford fosgate DVC subs...the amp is only 2 ohm stable in stereo mode and 4 ohm stable in bridged mode....i can only figure out to wire the subs into 2 ohms so should i still run them bridged or no?
projectprotege
Copper - Posts: 112
and it doesent sound good in stereo....what do you guys think? think ill be ok bridging them?
forbidden
Platinum - Posts: 5,352
Posted: March 09, 2005 at 3:53 PM / IP Logged
Sound is not a factor to be considered by the amp but by the speakers and the box. Do not confuse power output and control of the sub by the amp with better sound. Your amp is only stable to 2 ohms in stereo, while it may hold together in 2 ohms mono, it will only do this for a finite period of time before the magic smoke that makes it work is released. In other words, highly not recommended. The safe bet is to run the amp at 4 ohm per channel stereo of 8 ohm bridged. A better bet would be a second amp to drive the second pair of subs.
Chad7n7
Silver - Posts: 408
Posted: March 09, 2005 at 3:57 PM / IP Logged
Ahhh!!! Back to the magic smoke....... don't let it out, equipment doesn't seem to work after that!!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
