auto flip license plate
Trinity
Member - Posts: 36
Posted: March 11, 2005 at 2:53 PM / IP Logged
hey guys, my buddy and are building a 89 s10 long bed and i was wondering should i use a linear actuater or power window motor or air cylinder to operate an auto slide tag inside the tailgate so when the ignition is turned the tag will flip and when the ignition is off it will slide down, i've seen the pricie ones from silverstarcustoms and billet specialties but we aint spendings 500 buckaroos
aight ryan
auex
Platinum - Posts: 5,041
Posted: March 11, 2005 at 3:48 PM / IP Logged
Running from cops much???
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
c3d
Copper - Posts: 45
Posted: March 11, 2005 at 4:41 PM / IP Logged
there are cheaper ones, but i'd go with linear actuator
1987 Nissan 300ZX N/A
1994 Audi 90 Quattro CS
Sierra2700
Copper - Posts: 117
Posted: March 11, 2005 at 8:30 PM / IP Logged
Aeux, they are used so when you drive around they are out, but when you pull up to a car show your vehicle has a clean front or rear end with out the look of the license plate.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 12, 2005 at 12:57 PM / IP Logged
I made a bracket for a friends motorcycle. I hinged the factory tag bracket and used a power ant. to pull it up under the bike when he hit a switch. That was a long time ago. We didn't think much about doing stupid things then.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
streetstorm
Member - Posts: 12
Posted: March 15, 2005 at 9:32 PM / IP Logged
well to be honest with you  by the time u factor everything togeather it will almost come to about $500 bucks to do this cause if u use a actuator u are looking at almost 300 then brackets and fiberglass even!! then time  If u use air cylindrs then u are looking at air lines and a valve or 2 and then slow downs then wiring and switch   soo unless u do find something such as the window motor or power ant. motor and try to rig it thats the only way to save it all depends on the weight and room u have really!!
Ravendarat
Platinum - Posts: 2,806
Posted: March 15, 2005 at 10:36 PM / IP Logged
www.stylinconcepts.com , They sell a kit that is 199.99 that will do exactly what you are looking for
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
