resin on tape instead of fleece?
nyguy4u
Copper - Posts: 148
Posted: March 12, 2005 at 11:38 PM / IP Logged
Does resin stick to tape?. I am making very complex shapes and curves and whatnot.. and i'd be able to accomplish it using tape. After getting a thin layer of resin on the tape.. I plan on adding layers of matt to build it up, and just leave the tape there.
What tape is out there that resin will adhere too?. Masking tape?. It doesn't necessarily need to soak into it, but more of a foundation that I can add layers of matt to and build it up.
I hope I explained it right lol. Basically, instead of fleece.. I want to use tape.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 12, 2005 at 11:52 PM / IP Logged
Resin will stick to almost anything. I can't picture what your tring to do, but if fleece won't work, you can give tape a shot. I've never tried it. But I don't see why it wouldn't work.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
nyguy4u
Copper - Posts: 148
Posted: March 13, 2005 at 12:09 AM / IP Logged
I'll try to explain. I have a PT Cruiser. Basically.. I have fiberglassed box in my hatch. There is about 4 inches on either side from the side of the box, to the plastic trim of my car. Looking at it.. I decided I want it to look like it's actually molded into the hatch area, without making an entirely new box. So for the hell of it.. with masking tape, double layered.. I taped one end to the box.. the other end to the plastic trim, and did it on both sides, and covered every gap on the left and right side. So after looking it.. I thought maybe without having to go out and buy fleece, hot glue one end to the box, and the other to the plasic, that I could just lightly brush 1 or 2 layers of resin on the tape. Then after it dries, start adding layers of mat to build it up.
My concern is if whatever tape I use will loosen up once the resin touches it, that's why i'm trying to figure out what tape I should use to do this.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 13, 2005 at 12:36 AM / IP Logged
I see what your talking about. I'm not sure what tape you should use. Maybe experiment a little outside the car? I would think that as long as no resin got on the sticky side of the tape it shouldn't lose its stickem. It may get warm or cause the tape to contract though, so I would try it outside the car first. Sorry I don't have an exact answer.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
tnrplaya
Copper - Posts: 58
Posted: March 13, 2005 at 12:54 AM / IP Logged
I tried doing exactly what you are talking about with one of my first boxes...ended up looking like *hit. It is virtually impossible to get the shape symetrical. And as nyguy4u suggested the sape will definately fall or sag, thus f*cking your shape even more.
I suggest you do it with fleece, or better yet, fill the gap with expanding foam (after taping it off properly) then you can cut and shape the foam. Glass over that, and finally get rid of the foam with some gasoline (preferably AFTER removing it from your car:) I think you will be MUCH happier with the results.
Anyways, good luck and post pics!
PG Limited Edition Octane Aplifier
PG Ti400.2
(2) JL12w6v2
Focal 165KF
JL TR-690TXi
Sony XAV-7W
Sony 10 Disc MP3 Changer
X-box
APC 350W inverter
Monster 1/0
Irragi 180A Alternator
auex
Platinum - Posts: 5,041
Posted: March 13, 2005 at 10:09 AM / IP Logged
It will get warm and cause the adhesive to loose its stickyness. Also if you are using duct tape the resin will basically destroy it, I duct tape the bench if I am working outside the car, since it destroys the duct tape it won't stick to it and it comes up without destroying the bench.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
slociv
Member - Posts: 17
Posted: March 13, 2005 at 10:37 AM / IP Logged
Yeah, I wouldn't try using the tape as other have stated.
-SloCiv
44dawgs
Member - Posts: 31
Posted: March 14, 2005 at 11:50 AM / IP Logged
tnrplaya wrote:
Ifill the gap with expanding foam (after taping it off properly) then you can cut and shape the foam.
i've done that on a jetta, and it came out pretty well, just make sure to cover and tape evrythig, foam is very messy.
good luck
Asmodeus
Silver - Posts: 393
Posted: March 14, 2005 at 9:11 PM / IP Logged
Why not lay your tape then use spray glue to adhere the fleece to the tape...I dont know if it will work but sounds good in theory
Or maybe lay your tape then use layers of medical cloth tape...
I havent much experiance with Fiberglass so others may shoot my ideas down but heres my 2 cents...
resin on tape instead of fleece? -- posted image.
Making the World A Louder Place
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 14, 2005 at 11:04 PM / IP Logged
If you just want to buy more fleece, use an old t-shirt or something.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
