98 dodge caravan parking lights
dadz
Member - Posts: 33
Posted: March 16, 2005 at 12:28 PM / IP Logged
I am installing a crimestopper rs900vII on a 98 caravan. i switched jumper for parking lights to negative trigger. they will not work. i have tried 2 other new units with same result. any ideas will be greatly appreciated..
cutter1122
Copper - Posts: 103
Posted: March 16, 2005 at 12:31 PM / IP Logged
12volts red  +  ignition harness
Starter yellow  +  ignition harness
Second Starter
Ignition blue  +  ignition harness
Second Ignition BLACK/ orange  +  ignition harness
Third Ignition
Accessory BLACK/ white  +  ignition harness
Notes: Not required for remote start.
Second Accessory
Keysense
Power Lock WHITE/ green    left plug at bottom of fuse
Notes: Use relays and set up for negative trigger. Place a 4020 ohm resistor inline on the lock output, and a 665 ohm resistor inline on the unlock output. If you do not have a factory security system use a 1500 ohm for lock and a 250 ohm for unlock.
Power Unlock same wire    box under cover (1 of 3)
Lock Motor BROWN / yellow
Notes: The door lock motor wires are located in the top left plug at the relay/fuse box under the drivers side of the dash.
Unlock Motor BLACK/ pink
Parking Lights+ do NOT use
Parking Lights- grn/wht or grn/red    at light switch
Notes: If the van has auto lamps, see direct fax document #1080.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BROWN / lt. green  -  dome light on/off switch
Dome Supervision BROWN / white  -  dome light on/off switch
Trunk/Hatch Pin tied in with doors
Hood Pin do not use
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock see directfax 1081
Tachometer gray or gray/red  AC  ignition coil
Wait to start
Brake Wire WHITE/ tan  +  brake switch
Parking Brake
Horn Trigger gray/orange  -  top right plug of fuse box
Memory Seat 1
Memory Seat 2
Memory Seat 3
98 dodge caravan parking lights - Last Post -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
dare_ds69
Silver - Posts: 419
Posted: March 16, 2005 at 7:19 PM / IP Logged
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1080.pdf
how own your mind, control your life.
MECP certified. always use a DMM
desh187
Copper - Posts: 310
Posted: March 18, 2005 at 6:12 PM / IP Logged
try BLACK / YELLOW(+) at fuse block.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 19, 2005 at 12:40 PM / IP Logged
 . Also at the parking light relay under the hood.... 3rd relay up from the  front of the van, on the right side...solder POS(+) light flash to pin 87 of the relay....the one closest to the front of the van, then re-install the relay
nava94
Silver - Posts: 296
Posted: March 19, 2005 at 1:10 PM / IP Logged
you checked if you blew a fuse?I agree with kartuneman go to the parking light relay.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
