'04 Xterra Window Wiring
gtchida
Copper - Posts: 89
Posted: March 16, 2005 at 4:02 PM / IP Logged
I am installing window modules on an '04 Xterra and can't locate the window wiring diagram for this model - can anyone help?
Gary
dare_ds69
Silver - Posts: 419
Posted: March 16, 2005 at 6:30 PM / IP Logged
12volts green (40A)  +  ignition harness
Ignition BLACK/ white  +  ignition harness
Parking Lights+ blue/red  +  headlight switch
Parking Lights- N/A
Headlight red (L), RED / black (R)  +  headlight switch
Trunk/Hatch Release N/A
Power Sliding Door N/A
Speed Sense GREEN/ black    instrument cluster or ECM, pin 29
Notes: The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The VSS is in the 2nd row from the top, 4th pin right of center of the plug.
Wipers WHITE/ red (L), blue/white (H)  -  steering column
LF Window up/dn blue - blue/black  A  driver window switch in door
RF Window up/dn blue / YELLOW - blue/white  A  driver kick, door harness
LR Window up/dn GREEN/ YELLOW - GREEN/ red  A  driver kick, door harness
RR Window up/dn GREEN/ black - GREEN / WHITE  A  driver kick, door harness
Sun Roof open/close N/A
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
'04 Xterra Window Wiring - Last Post -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
how own your mind, control your life.
MECP certified. always use a DMM
gtchida
Copper - Posts: 89
Posted: March 17, 2005 at 9:48 AM / IP Logged
Thanks Dare!
Gary
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
