Audiovox APS775
Jpaudio
Member - Posts: 9
Posted: March 25, 2005 at 8:40 PM / IP Logged
i have a aps775 i cant get into prgraming the tach its on a silverado 02 i used the white wire under the fuse panel in the engine compartment i was on a harness not the fuse harness but on its own dont know if i got the right wire any help with be greatful. but like i was saying i cant get into programing the alarm i tried but it never sounds the siren to let me know that it worked also i cheked the switch to see if it was good it checked out i checked all the acc. wires going to alarm they checked out any ideas thanks
whiteshack
Member - Posts: 24
Posted: March 25, 2005 at 8:52 PM / IP Logged
to program tach on 775   turn ign. on    push valet switch three times  the siren will respond   turn ign. off
press and hold the valet switch and start the truck the lights will begin to flash------please note to have the foot brake down so you can see the lights flash--- release valet switch the lights will stay on and go out in a few seconds turn ign. off. programming finish.... the tach wire can be found by removing the four screws from the inst. cluster the tach wire is white
mecp certified installer
whiteshack
Member - Posts: 24
Posted: March 25, 2005 at 8:53 PM / IP Logged
Jpaudio
Member - Posts: 9
Posted: March 25, 2005 at 9:03 PM / IP Logged
on this alarm there is no push button its a switch and i tried to use the switch and it didnt work any other ideas
metaverse
Copper - Posts: 210
Posted: March 26, 2005 at 1:41 AM / IP Logged
I just installed this unit a while back..instructions below..
To program tach:
# Check valet/program flip switch is in off position.
# Turn ignition key to on position
# Flip valet/program switch on/off,on/off,on/off
# Turn ignition key off immediately
# flip valet/program switch on and start the car
# when tach signal is sensed, parking lights will flash
# Flip valet switch off. The parking lights will turn on
for 3 seconds to indicate tach learned and unit is out
of tach program mode
GREEN/ orange is tach on this unit. Make sure it is going to a valid tach feed.
Jpaudio
Member - Posts: 9
Posted: March 26, 2005 at 7:28 AM / IP Logged
is the tach that i got on the truck the right one
metaverse
Copper - Posts: 210
Posted: March 26, 2005 at 2:09 PM / IP Logged
I don't know that one..hopefully someone else will chime in that has worked on it..
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
