2005 Honda Odyssey Overhead Monitor/DVD
mme6342
Member - Posts: 6
Posted: April 01, 2005 at 9:27 AM / IP Logged
Anyone got any info on installing an overhead monitor into a 2005 Honda Odyssey?  Here's the setup I am told I am presented with (no tear down done yet):
'They' say it is factory prewired for an overhead monitor (obviously I have my doubts, can anyone confirm?) - It has a sunroof in it and side curtain airbags so I am a little leery...Does anyone know the true senstivity of these airbags?
Also, they did good and provided the Honda dash conversion kit to make a second DIN opening for the DVD player from a miscellaneous pocket below the factory stereo - the aftermarket DVD player is said to be able to interface with the factory stereo which does show and AUX mode.  Any wiring info for this?
Any help would MUCH APRECIATED!
mme6342
Member - Posts: 6
Posted: April 01, 2005 at 4:06 PM / IP Logged
Anyone got any info on wiring an aftermarket DVD player to the factory 2005 Honda Odyssey EX stereo?
CCroadshoptn
Copper - Posts: 67
Posted: April 01, 2005 at 11:35 PM / IP Logged
I've pot an aftermarket overhead video w/ built in dvd player in one. I don't know of anyway to wire an aftermarket dvd player like that into the stock radio, other than using an FM modulator. You will need 2 antenna adapters from metra the 40HD10 and 40HD20.  If it didn't already come with a stock  overhead video it won't be pre-wired for it. Hope that helps. Good luck
Mecp Certified
Double check advice with your Meter.
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
