Wiring diagram for 98 BMW z3
accent
Member - Posts: 13
Posted: November 11, 2002 at 8:15 AM / IP Logged
Does anyone have a wiring diagram for a 1998 BMW z3 to do keyless on this vehicle, any help would be appreciated.
Moderator - Posts: 12,488
Posted: November 11, 2002 at 8:40 AM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|green               |+  |ignition harness            |
|  SECOND IGNITION|purple              |+  |ignition harness            |
|        ACCESSORY|                    |   |                            |
|       POWER LOCK|lt. GREEN / WHITE     |+  |factory alarm plug *1       |
|     POWER UNLOCK|blue/red            |+  |factory alarm plug *1       |
| PARKING LIGHTS +|gry/ppl, gray / YELLOW|   |at light switch             |
| PARKING LIGHTS -|blue/green (hazards)|   |factory alarm plug *1       |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|brn/gry, BROWN / blue |-  |factory alarm plug *1       |
|  TRUNK/HATCH PIN|BROWN / white         |-  |factory alarm plug *1       |
|         HOOD PIN|PURPLE / green        |-  |*2                          |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|black               |   |*3                          |
|       BRAKE WIRE|blue/red            |+  |brake switch *4             |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|                    |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
NOTE: This vehicle is equipped with the EWS II immobilizer system that need to be bypassed when adding a remote start.  *1 12-pin, black factory alarm plug located behind glove box.  *2 Single pin plug next to the factory alarm plug.  *3 The wire is at the diagnostic plug in the passenger side rear of the engine compartment or can also find it behind the instrument cluster. Do not unplug the instrument cluster with the ignition on or turn the ignition on with the plug disconnected.  *4 Brake wire will only meter with the ignition on.
accent
Member - Posts: 13
Posted: November 13, 2002 at 10:28 AM / IP Logged
Thanks for the quick response Jeff    Wiring diagram for 98 BMW z3 -- posted image.
Andrew
Accent
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
