2005 chevrolet duramax diesel alarm
AZ-ss
Member - Posts: 31
Posted: April 13, 2005 at 6:12 PM / IP Logged
2005 duramax diesel alarm and remote start. Could someone post that wiring info?
Thanks.
KarTuneMan
Platinum - Posts: 7,056
wirewise
Moderator - Posts: 489
Posted: April 13, 2005 at 8:00 PM / IP Logged
12volts red (40A), red (40A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Power Unlock see power lock
Lock Motor gray   5wi driver door module in door
Unlock Motor tan   5wi driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug, pin B2
Hazards white   -   hazard switch
Turn Signal(L) dk. green   +   turn signal switch
Turn Signal(R) lt. green   +   turn signal switch
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger gray/blk (L), BLACK/ wht (R)   -   each door module in each door
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Wait to start dk. blue   -   instrument cluster, pin A2 or PCM
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   switch or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Immobilizer Bypass Module
~wirewise~
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
