2001 Buick Century
Welcome Guest :)
Parkdaddy02
Member -
Posted: November 14, 2002 at 6:37 PM / IP Logged
Can anyone get me the wiring diagram for a 2001 buick century.
Thanks,
Eric
Moderator -
Posted: November 14, 2002 at 8:16 PM / IP Logged
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness || STARTER|yellow |+ |ignition harness || IGNITION|pink |+ |ignition harness || SECOND IGNITION|white or green |+ |ignition harness || ACCESSORY|orange |+ |ignition harness || POWER LOCK|RED / black |- |drivers kick or BCM *2 || POWER UNLOCK|ORANGE / black |- |drivers kick or BCM *2 || LOCK MOTOR|gray | |drivers kick panel || UNLOCK MOTOR|tan | |drivers kick panel || DISARM DEFEAT|tan | |passengers kick panel || PARKING LIGHTS +|lt. blue | |at switch *1 || HEADLIGHTS|yellow |- |at switch || DOOR TRIGGER|dark blue/white |- |drivers kick or BCM *2 || DOME SUPERVISION|use door trigger | | || TRUNK/HATCH PIN|ORANGE / black |- |light in trunk or BCM *2 ||TRNK/HTCH RELEASE|brown |- |BCM *2 || TACHOMETER|pur/wht or white | |ignition control module || SPEED SENSE|GREEN / WHITE | |ECM under hood *3 || BRAKE WIRE|white |+ |brake pedal switch || HORN TRIGGER|black |- |steering column || WIPERS| | | || LF WINDOW UP/DN|blue - brown |A |drivers door switch || RF WINDOW UP/DN|lt blue - tan |A |drivers switch or kick panel|| LR WINDOW UP/DN|green - purple |A |drivers switch or kick panel|| RR WINDOW UP/DN|lt green - purple |A |drivers switch or kick panel|Notes:
NOTE: This vehicle is equipped with PASS-Key II (VATS). . *1 Larger of the two at the light switch. Can also find BROWN / white in the passenger kick panel in the harness to the rear. *2 BCM is to the left of the steering column *3 ECM is in the air cleaner assembly.Jeff
Parkdaddy02
Member -
Posted: November 14, 2002 at 8:38 PM / IP Logged
also can anyone tell me what the resistance is on the key because i need to figure out what size resistor to use.
Thanks,
Eric
Player69
Silver -
Posted: November 14, 2002 at 8:42 PM / IP Logged
You need to read it with an DMM. They are all different.
securinu
Silver -
you need to measure it thru the wire or get a bypass that learns the resistance.
Parkdaddy02
Member -
Posted: November 14, 2002 at 10:08 PM / IP Logged
can someone give me a diagram on how this hooks up with the resistor and relay
Thanks,
Eric
Parkdaddy02
Member -
Posted: November 15, 2002 at 8:19 AM / IP Logged
how many watts should the resistor be
Thanks,
Eric
Chris Luongo
Platinum -
Posted: November 15, 2002 at 8:31 PM / IP Logged
Most any good remote start includes a section on VATS bypass.
Thursday, May 16, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
