2002 Volkswagen Beetle Alarm/Remote Start Wiring
Guss
Member - Posts: 15
Posted: April 25, 2005 at 4:15 PM / IP Logged
Hi, I am installing a starter disable on a 2002 beetle. so, I want to know if someone could help me with the wiring diagram for this car.
I would appreciate if anyone could help me.
Thank you
Guss
thepencil
Gold - Posts: 1,526
Posted: April 26, 2005 at 8:22 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - VOLKSWAGEN / BEETLE / 2002 / Remote Start
12volts red    +   ignition harness
Starter RED / black    +   ignition harness
Second Starter
Ignition black    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ red    +   ignition harness
Second Accessory
Keysense
Power Lock yellow/lt.blue    -   inside drivers door
Power Unlock WHITE/ green   -   inside drivers door
Notes: Requires double pulse.
Lock Motor blue / YELLOW      inside drivers door
Unlock Motor purple / YELLOW      inside drivers door
Parking Lights+ gray/purple      headlight switch, pin 6
Notes: There are three gray/purple wires at the headlight switch, be sure to use the one that is in pin 6 to keep the dash lights fuse from blowing.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BROWN / yellow    -   theft module
Notes: The theft module is located to the left of the steering column.
Dome Supervision same as door trigger
Trunk/Hatch Pin BROWN / black    -   theft module
Hood Pin BROWN / red    -   theft module
Trunk/Hatch Release        theft module
Notes: Use BROWN / purple negative trigger on models with power windows, or RED / blue 5-wire positive on models without power windows. The fuel door can be released with a positive trigger on blue/red at the release switch.
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer GREEN/ YELLOW      ignition coil
Wait to start
Brake Wire RED / black    +   brake switch
Parking Brake
Horn Trigger BLACK / YELLOW    +   theft module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U, 555B or 555U
Notes: See DirectFax document 1056 for additional wiring information.
Be careful whose advice you buy, but be patient with those who supply it.2002 Volkswagen Beetle Alarm/Remote Start Wiring - Last Post -- posted image.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
