Circular motorization, how can I do it?
Asmodeus
Silver - Posts: 393
Posted: May 02, 2005 at 1:30 AM / IP Logged
Also something to consider using instead of the bearing you showed use a thrust bearing....It is designed to have weight pushed down on it and will not bind under loads...
Circular motorization, how can I do it? - Page 3 - Last Post -- posted image.
Making the World A Louder Place
ndm
Member - Posts: 31
Posted: May 02, 2005 at 9:51 AM / IP Logged
philbish wrote:
I appreciate all the help! I am going to order that christmas tree spinner :)
Let me know how it works out for you.  I just might pull out mine and do some experimenting
do it right the first time ....or do it again and again and again...
mlazzaro
Member - Posts: 9
Posted: May 02, 2005 at 1:33 PM / IP Logged
I have something that is perfict for that but they might be a little out of what you want to spend. they are made by oriental motor and are the hollow rotary actuators or the DG series motor.
http://www2.catalognavigator.com/orientalmotor/viewitems/linear-motion--1091/dg-series-hollow-rotary-actuators?&plpver=1018&forward=1&backtoname=&pane=
Oznium
Member - Posts: 24
Posted: May 02, 2005 at 5:26 PM / IP Logged
Starting at $1400 Circular motorization, how can I do it? - Page 3 - Last Post -- posted image.
I think I'd be better off fabricating something myself.
But I will look into this anyways and see if I can get some ideas.
abovestock
Copper - Posts: 247
Posted: June 10, 2005 at 7:36 PM / IP Logged
You could use a small motor using a small gear running a large gear on the outside circumfrence of your box. The motor would be stationary and would turn the box for you.
Page of 3
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
