5100rs On dodge durango 2000
One Eye Willy
Posted: April 27, 2005 at 12:12 AM / IP Logged
OK... I HAVE GONE BONKERS.... WHY CANT MY INSTALL BE SMOOTH.. CAUSE I GUESS I HAD TO GRAB LIFE BY THE HORNS AND GO STRAIGHT TO HELL...LOL...ANYWAYS YEAH ITS A DODGE....
WELL MY PROBLEM IS THIS:
1. EVERY WIRE IS ON CORRECT... THE STARTER WORKS GREAT... THE HORN.. HOODPIN AND ALL BUT THE DAMN DOORS...
2. NOW IM VERY INTELIGENT BUT DAMN.. OK... THIS IS THE ONLY NEEDED COLORS FOR THIS OPERATION... HELPPPPP ME PLEASE!!!!
DODGE DURANGO 2000 SLT PLUS! keyless.....
Factory Alarm Disarm LT.GRN/ORG(-)
FACTORY ALARM ARM SAME AS DISARM
PowerUnLock PNK/VIO (+)
PowerLock ORG/VIO (+)
HAVE TO REVERSE POLARITY
DriverDoorMotor01 BLUe (+)
DriverDoorMotor02 ORG/BLk (+)
PassengerDoorMotor01 PNK/BLK
DOOR TRIGGER YELLOW (-)
DRIVERS DOOR BLK/BLUE
ALL OTHERS TAN/RED
TRUNK TAN/BLK
THE ALARMS COLORS FOR ANYTHING THAT SAYS DOORS:
VIOLET DOOR TRIGGER INPUT (+)
GREEN DOOR TRIGGER INPUT (-)
VIO/WHT FACTORY ALARM DISARM
WHT/VIO FACTORY ALARM ARM
AND ALSO I DONT KNOW IF THIS IS JUST OPTIONAL BUT THERE IS A
3 PIN WHITE DOOR LOCK CONNECTOR
BLUE NEGATIVE UNLOCK (-) 500 MA
RED (+) 500MA TRIGGER OUTPUT FOR OPITIONAL PLUG IN-DOOR LOCK RELAY
GREEN NEGATIVE LOCK OUTPUT (-) 500 MA
OK SO WITH THAT SAID.... THE SCYTEK COMPANION SOFTWARE DESCRIBES THIS..
WHEN EQUIPPED WITH KEYLESS ENTRY THE DOOR WIRES WILL BE POSITIVE IMPULSES... MODELS EQUIPED WITH A FACTORY ALARM HAVE A ONE WIRE TO PERFORM ALL DOORLOCK AND SECURITY FUNCTIONS..
A single wire is used to lock and unlock the doors. Lock requires a negative trigger through a 647 ohm resistor. Unlock requires a negative trigger through a 1563 ohm resistor. Unlock requires a double pulse to unlock the doors. The first pulse disarms the factory security. Relays must be used.
OK IM NOT TO UP ON RESISTORS AND DIODES BUT 12VOLT.COM EXPLAINS THEM WELL... BUT RADIOSHACK IS NOT HOW IT USED TO BE WITH KNOWLEDGABLE STAFF AND I JUST PUT TOGETHER WHAT I LEARNED... I GOT A 680 OHM FOR THE 647... PUT TWO 680 AND ONE 220 IN A SERIES ADDING UP TO 1580 FOR THE 1563... DIDN'T KNOW IF DIODES WERE NECCESSARY FOR THE ONE WIRE TRANSMITTING TWO DIFFERENT SIGNALS (-)(+) SEEMS LIKE IT BUT EVERY DIAGRAM I LOOKED AT NEVER ASKED... SO I DIDN'T DO THAT PART... WELL I SPLICED INTO THE FACTORY ARM/DISARM WITH ONE WIRE LEADING TO A SPLIT FOR THE ONE DIODE (LOCK) AND THE THREE DIODES (UNLOCK) SERIES.... THEY BOTH CONNECTED TO SEPERATE RELAYS AS SO... EACH TO 30, 87A N/C, 87 CHASIS, 86 12V CONSTANT OFF THE STEERING HARNESS, 85 TO (-) ALARM REMOTE STARTER.....
TURNING ON SYSTEM LED TO REALIZING I HAD CONNECTED THE BLK/WHITE OFF THE ALARM (DOMELIGHT OUTPUT (-) 500MA WHICH THE MANUAL SAYS CAN BE CONNECTED TO THE DOOR TRIGGER INPUT (SEE GREEN AND VIOLET) TO THE PNK/VIOLET (POWER UNLOCK) OF THE VEHICLE THROUGH A RELAY (87, POSITIVE DOMELIGHT, 86, BLK/WHT -DOMELIGHT OUTPUT, 30 AND 85 TO 12V CONSTANT ON STEERING HARNESS) ... AS I WRITE THIS NOW REALIZING DOOR TRIGGER AND POWER UNLOCK ARE TWO DIFFERENT THINGS... ANYHOW.. THE UNLOCK FUNCTION WORKED ONLY BY PRESSING THE DISARM BUTTON BUT ARM DID NOT ARM WHEN DISPLAYING ARMING ON THE LCD... DISSCONECTING THIS WIRE FROM THE POWERUNLOCK ONLY LET ME ARM THE SYSTEM THROUGH THE DISARM BUTTON NOT THE ARM.. IT ONLY SAID ARM BUT DID NOT ACTUALLY ARM ON THE ARM BUTTON....
IM SORRY... SORRY... FOR THE LONG EXPLANATION... BUT I READ SO MANY FORUMS AND THE KNOWLEDGABLE AND WILLING TO HELP PEOPLE GET THOSE PEOPLE THAT SIMPLY WRITE UNANSWERABLE SHORT QUESTIONS THAT NEED MORE INFO.. WELL I PUT YOU THERE.... IM NEW TO THIS OK... LOL... HAVE A GOOD DAY GUYS... BELIEVE ME I'LL BE WAITING??????THANKS
Powermyster
Silver - Posts: 962
Posted: April 27, 2005 at 4:22 AM / IP Logged
SO you have the unlock working...
What i would do is to give the wire that you suspect of being the lock wire a touch of a 12V feed because its a + trigger if the door locks you have the right wire
I've only done a few installs with alarms but never had to use resistors i dunno what thats all about
niper0108
Member - Posts: 15
Posted: April 27, 2005 at 7:50 PM / IP Logged
Email me directly & I'll walk you thru it. You have way too much stuff all wired together, and you may have damaged the unit when you connected the blk/wht domelight outout wire direct without a relay. I'm a Scytek dealer / installer...
niper0108@yahoo.com
KarTuneMan
Platinum - Posts: 7,056
Posted: April 28, 2005 at 12:08 AM / IP Logged
Man Willy....can you type5100rs On dodge durango 2000 -- posted image.
ziggyb222
Silver - Posts: 593
Posted: April 28, 2005 at 9:16 AM / IP Logged
KarTuneMan is right Willey...You can type.. but anyways get a DEI 451m and it comes with all the resistors you need.. and all the wiring diagrams you need.. all in one unit an prewired...just a thought
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
