Alternator Wiring Question
lakers08
Copper - Posts: 75
Posted: May 09, 2005 at 10:06 AM / IP Logged
I drive a 2001 Civic and have upgraded my alternator and two of the "Big Three" wires. Using 1/0 gauge wire, the battery/chassis and alternator/battery cables were replaced. The shop did not upgrade the chassis/engine wire; the mechanic said it wasn't necessary as the housing for the alternator was connected to the engine block.
Is there a potential for problems if this wire isn't replaced as well? Could it create problems for the alternator, battery or components? I'm of the belief that he didn't upgrade the chassis/engine wire because it was difficult to access.
c3d
Copper - Posts: 45
Posted: May 09, 2005 at 10:16 AM / IP Logged
It should be fine. The chassis/engine wire is mostly a performance factor. If replaced, you will probably get a better result in the end, in terms of how your car operates, or the equipment you're running. it will not damage anything however
1987 Nissan 300ZX N/A
1994 Audi 90 Quattro CS
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
