question about grounding HU
midnight wolf
Member - Posts: 13
Posted: May 13, 2005 at 8:23 PM / IP Logged
Just got a question regarding the grounding of a head unit. If the factory harness has the black ground running in it should I hook up the ground from the HU harness to that or should the HU ground be run to somewhere else? I guess what i want to know is cani connect black to black from hu to factory harness? Thanks
Lthlquicksilver
Member - Posts: 47
Posted: May 13, 2005 at 9:05 PM / IP Logged
I always ground to the factory harness unless there is a wiring problem, in which case I run my own ground.  If the factory stereo was working, the ground was good.  If you're not sure, just hook it up to a multi meter and see what resistance it reads.  It should read 0.00 if it's a good ground.
Muscle Cars Don't Just Look Good, But They Can Sound Good Too...
1971 Chevelle SS
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
