Door locks in Windstar 95
jorgefdz
Copper - Posts: 99
Posted: November 17, 2002 at 10:41 PM / IP Logged
I can't conect the doorlocks....
How  can I connect it..  I know that the door lock is  pink / YELLOW and door unlock pink/green, but i dont know how...
j.f.l.l.
Moderator - Posts: 12,488
Posted: November 17, 2002 at 10:48 PM / IP Logged
Take the UNLOCK wire from the RS or alarm harness and attach to the PINK/GREEN wire that tests (-) when you press the unlock button on the door. The wires are located in the driver's kick panel and if you have the keyless entry module it is located behind center storage compartment. Look for these two wires and test them to make sure they are the proper ones with a DMM. You need to do nothing else except attach the two wires unless the unit that you are installing requires you to tell the system wether or not is is a (-) or a (+) trigger system by attaching a wire to either GROUND or CONSTANT 12 volts.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
