my little project so far with pics
ChrisZ3
Member - Posts: 35
Posted: June 08, 2005 at 9:18 AM / IP Logged
@1hot944
I mixed an amount of bondo with some resin and a little acetone until i have an almost liquid mix. then added some hardener and mixed well again. I didn't use any ratio. It's the first time i was trying that and it came out very well. The mix is alot easier to apply with a brush and is time saving. Let cure and start sanding.
audiomechanic
Silver - Posts: 388
Posted: June 08, 2005 at 12:22 PM / IP Logged
what method did you use to strengthen the enclosure???
and also are you using liquid bondo to build up and shape the enclosure???
ChrisZ3
Member - Posts: 35
Posted: June 08, 2005 at 12:38 PM / IP Logged
@audiomechanic
I layed on the inside 4 layers of mat. I am also going to put some rope dipped in resin on the inside.
audiomechanic
Silver - Posts: 388
Posted: June 08, 2005 at 12:43 PM / IP Logged
the rope thing is for if you are gonna add more layers......it is to give the mat and resin curves because that is where the strength comes from(curves)..... so if you are just gonna resin some rope to the outer layer, it prolly wont do much good unless more layers are added on top of the rope.
LatinMax
Member - Posts: 38
Posted: June 09, 2005 at 6:55 PM / IP Logged
I usually use just resin to thin the bondo. If you use acetone it will make it too brittle. At least for paint purposes.
Having Fun in Texas!
"LatinMax"
kps67
Member - Posts: 25
Posted: June 09, 2005 at 10:52 PM / IP Logged
latinmax how well does bond thinned with resin hold up on subwoofer enclosures
HottAccord
Silver - Posts: 247
Posted: June 09, 2005 at 11:48 PM / IP Logged
Wow, thats a nice clean job! I like it, cant wait to see the final product! my little project so far with pics - Page 2 - Last Post -- posted image.
Im a fiberglass whore!!
DukeDuke
Silver - Posts: 206
Posted: June 10, 2005 at 12:41 AM / IP Logged
ChrisZ3, what hardner did you use for the mixture? resin or bondo? I have heard of this being done, more so with resin and acetone, not so much bondo, but have wondered if this was possible, since I am sure that is all spray bondo is. Just wasn't sure as to which chemical to mix in with it. But does look good so far. I hope to see it fully finished. I will be starting mine tomorrow, which is a complete trunk install with a false floor in a 99 Maxima. I will post pics, but please let me know about your mixture. Thanks!
Duke Duke
LatinMax
Member - Posts: 38
Posted: June 10, 2005 at 1:50 AM / IP Logged
kps67: It holds up great. You can add as much fiberglass resin as you want to it and get it pretty runny. That is what I do when I need to fill in small gaps, pin holes or small caveties that need a little more strength (tweeter pods) and then I use bondo hardener.
If the space is to big then I use ground up FG or cotton flux to thickin up the stuff.
"LatinMax"
05honda
Copper - Posts: 100
Posted: June 18, 2005 at 12:46 PM / IP Logged
I like the idea of thinning the bondo iwth resin....The cotton flux ground up sounds like alos a good idea although ive never tried it....Very nice box by the way...post the finished product when you get the chance...Cant wait to see it
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
