new volfenhaug 12's
hossdillon
Member - Posts: 9
Posted: June 11, 2005 at 6:32 PM / IP Logged
i just got 2 new comp series 12" subs i tried to hook them up the way they said in the manual for ohms 2 -4 -or 8 i tried the 2 ohm set up however when one speaker was hooked up it sounded good when i connected the other they muffled out ( rockwood X plorer 1600 watt) so i tried running them bridged and still the same outcome when i hooked the + up on each channel and connected the - to the same terminal they sounded a little better but not near the sound that i anticipated, i took the speakers out of the box about 7 times trying everything in the book (keep in mind it is a bandpass with a million screws) the only way i can get them to push "ok" is running a single coil on each speaker?....... any suggestions on how to hook up both coils on each speaker and get it to the full potential? any suggestions on where to adjust the "gain", Bass boost , bass freq and low pass filter would also be a great help. thanks!!!!!!!!!!!!!
maxxedout89
southside
Copper - Posts: 220
Posted: June 11, 2005 at 7:16 PM / IP Logged
reverse the polarity on the hook up on the amp. meaning the positive wire from the sub to the neg on the amp. it has helped me before
southsider
stevdart
Platinum - Posts: 5,816
Posted: June 11, 2005 at 10:11 PM / IP Logged
If the manual tells you 2,4 or 8 ohms, they're DVC 4ohm subs.  With two of them, here are your wiring choices:
new volfenhaug 12's -- posted image.
They SAY 2,4 or 8 ohms but the choices are really 2 or 8 per sub.  The 4 is thrown in there because TECHNICALLY if you use just one voice coil the sub will be 4 ohm.
(If the subs are NOT DVC 4 ohm, post a response and go no further.)
The second diagram above, with subs wired series/parallel, is the only way you can go.  This setup should work with any amp.  Whatever Rockwood is, they should provide you with a user's manual to show how to use the features.  But here is the basics - the gain is the input level control, probably a screw.  Turn it counterclockwise all the way to the stop.  With the system setup completely and subs wired as shown above, play a CD.  You will barely hear it, but turn the deck up until the sound gets like it sounds "forced".  That should be about 3/4 up on the volume control.  When you get to that point where you hear the sound start to sound strained, turn it back down a little.  That's the maximum clean output of the deck.
To set amplifier gain at this time, turn the screw clockwise slowly...the sound will come alive.  It may not take much of a turn to get to the point where the music starts to lose its clarity, sounding "strained".  Just like you did with the deck, turn the amp's gain back down a slight bit until you are satifsfied that the music sounds good, although it will be at maximum volume so be careful.  You have now successfully set the gain.
Bass boost is for idiots, so leave it off or at minimum.
An amplifier will have built-in active crossovers for high pass (to speakers or components) and low pass (to the subwoofer).  Take your time listening to a variety of your favored music sources and adjust those until you have a smooth transition of sound from the speakers to the subwoofer.  This part doesn't have to be scientific...it's all about how it sounds to you.
hossdillon
Member - Posts: 9
Posted: June 12, 2005 at 12:58 AM / IP Logged
thanks i linked the top two coils together from one sub to the other and ran the +,- on the bottom two out reversed polarity on one sub so i had +- on the + of the amp and +- on the - side bridged it sounds better but still for some reason still not the hard low bass i was getting out of my fosgate DVC's that i blew and silliconed back together.......... hmmm what about the bass freq? and low pass is half way proficient in catching the lower notes?
maxxedout89
speedwayaudio1
Silver - Posts: 879
Posted: June 12, 2005 at 4:20 AM / IP Logged
don't even think you will get the sound from a volvenhaggg, that you will get from a Fosgate.
Big Dave
Audionut4u
Posted: June 12, 2005 at 5:38 AM / IP Logged
I happen to have two of the comp. Volfenhag 12's.... And they are set up on an Autotec Mean Machine. I ran them parallel on the two channel for a 2 ohm stereo load. In the box I built for them they sound pretty good. They are comp subs so I entered and hit almost 143.0 on a Term-lab at a Usaci Outlaw event. I havent had any loudness issues out of mine, and sometimes it gets to be over-powering to be honest... Hope this post is helpful and not too late.  B.W.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
